Firewall Question
Firewall Question
Postby frak » Fri Aug 05, 2005 7:54 pm
I was just wondering what the views of the forum would be regarding the setting up of a home network.
I currently have a D-Link DSL-604GT router that I am only using for wired networking. What I want to know is whether or not I am better off using the inbuilt firewall or having a dedicated machine for the task. I plan to have two pc's and eventually a laptop on the network as well as a ps2 and xbox.
Many thanks...
frak
RE: Firewall Question
Postby jjmac » Mon Aug 08, 2005 1:19 am
You mean 'iptable' ... yes configure iptables. What ever technique you use ... whatever sw you use, it will basically just be fronting for iptables.
http://counter.li.org
Postby towy71 » Mon Aug 08, 2005 8:34 am
The router has iptables already setup so why wouldn't you use that?
to quote from their website:
# Web-based configuration
# Firewall
# Virtual Private Network (VPN) pass-through support
Dick
