SOLVED: Mounting Creative PC-CAM 880 camera
Postby alloydog » Tue Aug 16, 2005 5:30 am
I it is udev, as there is a message at boot up that devfs is not supported but that kernel.
Though I have just been through both messages and dmesg but cannot find reference to either devfs or udev. Though I did find udev in /etc, /etc/init.d and /sbin, with devfs only in /etc.
I'm just going through the udev-FAQ now, but since I have left the camera at home, I won't be able to test anything intil the weekend...
alloydog
Postby nelz » Tue Aug 16, 2005 8:05 am
df -T dev
will show you which is in use.
Postby alloydog » Tue Aug 16, 2005 8:10 am
:/# df -T dev
Filesystem    Type   1K-blocks      Used Available Use% Mounted on
/dev/hda1 reiserfs     4687468    989828   3697640  22% /
root@voyager:/# df -a
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/hda1              4687468    989828   3697640  22% /
proc                         0         0         0   -  /proc
sysfs                  4687468    989828   3697640  22% /sys
devpts                 4687468    989828   3697640  22% /dev/pts
usbfs                        0         0         0   -  /proc/bus/usb
/proc/bus/usb                0         0         0   -  /proc/bus/usb
usbdevfs                     0         0         0   -  /proc/bus/usb
/dev/hda3              4882596    312648   4569948   7% /mnt/hda3
alloydog
Postby nelz » Tue Aug 16, 2005 8:16 am
Soory, that should have read
df -T /dev
Postby alloydog » Tue Aug 16, 2005 8:19 am
Just the same:
:/# df -T /dev
/dev/hda1 reiserfs     4687468    990128   3697340  22% /
alloydog
Postby nelz » Tue Aug 16, 2005 8:41 am
According to this, you are running a static /dev, not udev or devfs. Which distro is this?
Postby alloydog » Tue Aug 16, 2005 8:46 am
BeatrIX
It uses the 2.6.7 kernel.
alloydog
Postby nelz » Tue Aug 16, 2005 9:27 am
This is a very small distro, maybe it's missing whatever your camera needs. Have you tried a larger live CD distro, like Knoppix or Kanotix?
Postby alloydog » Tue Aug 16, 2005 9:44 am
Not for some time. I chose this one because it installed and ran on several old PCs (450 MHz AMD) quite nicley, with the minimum of fuss. I just recently tried Ubuntu 5.0.4, but that had problems with my graphics adapter, sound card and network adapter.
alloydog
Postby nelz » Tue Aug 16, 2005 10:26 am
I meant to just try it as a live CD to see if it handles your camera. Then you can see what it uses and set up BeatriX the same way.
Postby alloydog » Tue Aug 16, 2005 10:30 am
Aha, I never thought of that :oops:
I am also going to upgrade the kernel to 2.6.12-whateverthecurrentversionis....
alloydog
Postby alloydog » Thu Sep 01, 2005 9:04 am
SOLVED.
After installed an updated kernel, 2.6.12-6-686, I modified fstab by replacing the entry for usbdevfs with usbfs and adding the line:
/dev/sda1...../camera.....vfat.....defaults,noauto.....0.....0
Then after mounting /camera, I can see and browse to the proper directory within the camera.
alloydog
RE: SOLVED: Mounting Creative PC-CAM 880 camera
Postby nelz » Thu Sep 01, 2005 10:20 am
It seems like the older kernel may not have had the support needed for this device.
Postby alloydog » Thu Sep 01, 2005 10:23 am
It isn't so much for the device, more for the filesystem - the camera is treated just like a USB mass storage device.
alloydog
Postby nelz » Thu Sep 01, 2005 3:14 pm
But you're mounting it with the vfat filesystem, that's hardly new.
PreviousNext
