mount ntfs partitions
Postby cbbahn » Wed Aug 03, 2005 11:48 am
Dear Geeks,
I newly installed Fedora Core 4 on my laptop and I am quite satisfied.
The only problem is that FC4 doesn`t automount my NTFS partition, because it doesn`t appear in /etc/fstab.
Do you have any idea what I have to alter in this file?
Many thanks and kind regards,
Christopher
cbbahn
Postby bigbee » Thu Aug 04, 2005 8:28 am
Insert
/dev/hda1       /mnt/C  ntfs    user,gid=users,umask=0002,iocharset=iso8859-1 0 0
where /dev/hda1 is your ntfs partition and /mnt/C is your mountpoint. You can also play with your mountoptions, but these work for me on a SuSE 9.3 machine
bigbee
FC_4 ntfs mount
Postby lok1950 » Fri Aug 05, 2005 10:06 pm
under fedora there is no native ntfs suport you need a kernel module here is a link to staton Finley's fedora 4 intsallation notes good resouce his privous FC3 note were just as helpful
http://stanton-finley.net/fedora_core_4_installation_notes.html
good luck !
lok1950
RE: FC_4 ntfs mount
Postby ollie » Sun Aug 07, 2005 5:16 am
The actual application is captive-ntfs although this not being developed any further. Windows XP SP2 actually breaks captive-ntfs but there is a work around published by O'Reillty Net. You can also try the packages from Knoppix and its' bretheren Live CD/DVDs.
Hope this helps!
