drt
Posted: Sat Jul 30, 2005 6:16 pm Post subject: Can anyone please recommend a distro? |
Hi
I was wondering if anyone could please recommend me a Linux distro to use?
I have an AMD 64 3000 processor, running on an K8NS Pro motherboard, with 512mb RAM.
I don't use my computer as a server, so need something which is quick to load on startup. I currently run FC3 which takes about five minutes to boot up to the desktop, which is too long.
I'm not a complete Linux novice, but wouldn't say I was a power-user, either. I prefer the Gnome desktop, and was wondering if anyone had any suggestions as to the best distro I could install?
Many thanks in advance for your help!
drt |
coolclassic LXF regular
Posted: Sat Jul 30, 2005 7:33 pm Post subject: RE: Can anyone please recommend a distro? |
Why not try Ubuntu. I use Kubuntu which favours KDE. Ubuntu is fast loading and easy to config down loads are a singe using synaptic or even apt from command line. Have a look at there forums if you don't believe me.
http://ubuntuforums.org/ _________________ The world is your playground why don't you play. |
bigbee
Joined: Thu Jun 09, 2005 3:46 pm Posts: 55 Location: Westerlo, Belgium
Posted: Sat Jul 30, 2005 10:45 pm Post subject: RE: Can anyone please recommend a distro? |
Maybe if you disable some of the services that startup at boottime you can speed up your boot-time.
Maybe you can try out debian (or one of its offspring) which let you install a minimalistic system (which can be expanded at your needs) instead of an all-in-one-preconfigured distro like RH, SuSE or Mandriva. _________________
jer1ch0 LXF regular
Joined: Sat Apr 09, 2005 11:42 am Posts: 135 Location: Ireland
Posted: Sat Jul 30, 2005 11:35 pm Post subject: RE: Can anyone please recommend a distro? |
| I second Ubuntu. It's got Gnome, that you want, Synaptic package management - excellent; Aand excellent help at the Ubuntu forums. |
RD LXF regular
Joined: Mon Jul 25, 2005 3:53 am Posts: 272 Location: irc.ixl2.net
Posted: Sat Jul 30, 2005 11:46 pm Post subject: RE: Can anyone please recommend a distro? |
I like mandrake though at the mo its giving me a head ach with the microphone but other than that its all good  _________________ [url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url] |
drt
Posted: Sun Jul 31, 2005 6:24 pm Post subject: RE: Can anyone please recommend a distro? |
| Thanks for all your help, I will try Ubuntu as suggested, and let you know how I get on. |
marco.auer
Joined: Sun Jun 26, 2005 12:02 am Posts: 4 Location: London, UK
Posted: Wed Aug 24, 2005 1:21 pm Post subject: RE: Can anyone please recommend a distro? |
| I would also go for Ubuntu. It is easy to use and can be very powerful. |
