Upgrade
Upgrade
Postby RD » Sat Jul 30, 2005 9:53 am
Hi
Last night i was looking through kde and saw the new version and thought wow how nice it looks so my question is how can i update mandrake 10.1 to use the new kde ?, also while im here i also found a useful tool called xvidcap :D, i installed it using mandrakes urpmi all went well till i started it from cli using gvidcap -v where i got a segmentaion fault no matter what options i try i always get the same fault then the app ends any one know why or how to fix it ?
RD
RE: Upgrade
Postby RD » Sat Jul 30, 2005 11:10 am
OK after i got round that dep problem (for upgrading xvidcap) now i get a new error that i've not seen before ?
gvidcap -v
job.job_set_file(): Original dimensions: 192 * 144
Output not a video file or no counter in filename
Disabling autocontinue!
control.InitControl(): Original dimensions: 192 * 144
Current settings:
frames per second = 30.000000
video encoding = MS_DIV2
file pattern = test.mpeg
verbose level = 1
frames to store = 0
time to capture = 0.000000 sec
autocontinue = yes
compression level = 0
quality (jpeg) = 100
input source = shm (16)
capture pointer = black
capture audio = no
- input = /dev/dsp
- sample rate = 22050
- bit rate = 32000
- channels = 1
animate command = animate "%s" -delay %d &
make video command= ppm2mpeg "%s" %d %d %d %d %f %d &
edit frame command= display "%s" &
help command = xterm -e man xvidcap &
Original Selection geometry: 663x470+274+245
Modified Selection geometry: 662x470+274+245
color_table first entry: 0x00000000
job.job_set_file(): Original dimensions: 662 * 470
gvidcap: symbol lookup error: gvidcap: undefined symbol: __fixunsdfdi
any one know what that is ?
RD
RE: Upgrade
Postby Gordon » Sat Jul 30, 2005 1:04 pm
This looks like a problem with a shared library. gvidcap, or one of the libraries it is linked with, is looking for a function, constant or variable called __fixunsdfdi in a shared library and cannot find it, hence the undefined symbol error.
Since you installed using urpmi I assume gvidcap was pre-compiled. Try getting the source code and compiling from source. This should help to determine any library dependancy problems.
Gordon
RE: Upgrade
Postby RD » Sat Jul 30, 2005 2:14 pm
OK will give that a go, any chance you know how to get mandrake to use kde 4.x ?
RD
RE: Upgrade
Postby Gordon » Sat Jul 30, 2005 2:26 pm
No not a chance. :( I usually stick with with the version of KDE and/or GNOME which is supplied with the distro I'm using. In the past I've tried to update KDE and GNOME on SUSE Linux (various versions) and have ended up having to re-install. The problem with a KDE/GNOME upgrade on one of the ready made distro's is that each distro might do things differently to the others. SUSE, for instance, puts KDE in /opt/kde whereas Slackware tends to place everything in /usr.
The only time I've installed a brand new KDE is when building a Linux From Scratch system, see
http://www.linuxfromscratch.org/
and this is difficult enough. If you want an easy life then stick with what you've already got.
If it isn't broken, don't fix it :)
Gordon
RE: Upgrade
Postby nelz » Sat Jul 30, 2005 3:41 pm
Konstruct will install the latest KDE from source for you. By default, it installs into your home directory, so it won't affect your current set up.
http://developer.kde.org/build/konstruct/
