Is there....
Is there....
Postby RD » Thu Jul 28, 2005 3:49 pm
Hi
Im woundering if there is a tool to convert an avi to mpg/mpeg then to .vob and all the other types of files a dvd would need to play on a standard dvd player (the tv type not pc type), ive had a look at tovid and when i came to install it i complained that the depens was not met which i found stange as most of them are required by dvd::rip
Thanks
RD
RE: Is there....
Postby Erin » Thu Jul 28, 2005 6:20 pm
tovid seems to be the kiddy. What distro do you use?
Erin
Erin
RE: Is there....
Postby nelz » Thu Jul 28, 2005 6:34 pm
Why not install the missing dependencies? Most of them isn't enough :(
Postby RD » Thu Jul 28, 2005 6:40 pm
cause it says all of them are missing when i know for a fine fact there installed :D
Mandrake 10.1
RD
Postby nelz » Thu Jul 28, 2005 6:57 pm
How are you trying to install it, from source or an RPM file?
Postby RD » Thu Jul 28, 2005 8:50 pm
Im trying the source, did try mandrake's urpmi but it did not find an rpm :(
RD
Postby nelz » Thu Jul 28, 2005 9:20 pm
It is likely you need to install the -devel RPMs for the dependencies.
Postby RD » Thu Jul 28, 2005 11:09 pm
Nope as i know just how much of a pain it can be to install apps i try to always install the devel pacages :D, after a little playing around i finally got it to install apart from it complained that mplayer was not uptodate, how ever i can live with that as it still worked :D
Thanks
RD
