Mandrake 10.1 sound [SOLVED]
Postby RD » Mon Jul 25, 2005 4:26 pm
Hi
every time i boot into mdk 10.1 i have to try and get the sound going again its using oss i810_audio driver module ive tryed loggin as root get it set up and then i need to reboot because wine wont run what i want then when im back in mdk i have to spend no less then 10 mins every time trying to get sound going again
Any ideas as to how to solve this ?
RD
RE: Mandrake 10.1 sound
Postby M-Saunders » Mon Jul 25, 2005 4:57 pm
What do you mean by 'get sound going'? What do you have to do for that?
M
M-Saunders
Postby RD » Mon Jul 25, 2005 5:27 pm
go and set it backup again choose the drive etc etc = get it going
RD
Postby RD » Mon Jul 25, 2005 5:42 pm
Here are some ss to show you rather then try tell you :D
Here is what i get when i login to mdk
then i do the fillowing and click on the run config tool
[img][img]http://img.photobucket.com/albums/v621/Drakx/sound-error1.png[/img]
choose i810_audio and sounds there just very very low :( i have to go through this proccess every time i log in to mdk and don't under stand why
RD
Postby RD » Wed Jul 27, 2005 5:57 pm
It would seem that there was a fix in the mdk updates that did the job :D
RD
