UT2004:SAS seg fault
Postby tedius » Mon Jul 25, 2005 2:48 pm
First of I let you know what my system is.
Athlon XP 1800+, 256Mb, GForce4 MX440
I'm running Ubuntu that cam with LXF a few months ago, and UT2004 with the latest patch.
My problem is that when I start the SAS UT2004 game I get to the main screen, but then when I select any of the menus I get a seg fault.
My question is, has anyone else seen this and if so have you managed to get it to work?
Thanks
tedius
RE: UT2004:SAS seg fault
Postby AudioMove » Wed Jul 27, 2005 2:20 am
i've heard to try this
cd /usr/local/games/ut2004/System
ln -s /usr/lib/libSDL-1.2.so.0 libSDL-1.2.so.0
That fails, google it
AudioMove
