limewire install probs?
Postby 1slipperyfish » Sun Jul 24, 2005 3:25 pm
hello i am running mandriva 2005 le and i canot seem to install using urpmi?
i have already installed jre in /usr/java the rpm is in /home/paul and when i try to install it in /home/paul(as i cannot find where you are supposed to install it) i get
Some package requested cannot be installed:
LimeWire-free-4.8.1-0.i386 (due to unsatisfied j2re[>= 1.4.1])
but i have jre1.5.0_04 installed? also i tried to install limewire in /usr/java bit i don't seem to have permission to do so?
any help would be appreciated as i've been at it since 12 o'clock and my head hurts :cry:
paul
1slipperyfish
Forum Jester
RE: limewire install probs?
Postby Rhakios » Sun Jul 24, 2005 3:42 pm
Did you install java as an rpm? The rpm database only knows about aplications installed using rpm. You could always use the --allow-force option to override if you are sure you know what you are doing.
Postby 1slipperyfish » Sun Jul 24, 2005 8:45 pm
no i installed jre from binary, i have tried forcing it shouting at it and threatened it with a sound birching :x all to no avail :roll:
i'm off to have a play with graham 8)
paul
1slipperyfish
Forum Jester
Postby A-Wing » Sun Jul 24, 2005 9:35 pm
You tried using "rpm -Uvh --nodeps LimeWire-free-4.8.1-0.i386" this is not the best option but it should work. The recommended option is to uninstall your binary and use the RPM of j2re instead.
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby 1slipperyfish » Mon Jul 25, 2005 7:56 pm
i have downloaded the jre rpm the problem i am now having is removing the directories /opt/java and usr/java :? i have used rmdir, rm -r but even after i go through all of the files individually(there are a lot :shock: ) using rm -r, when i use l -l they are still listed and if i open konqueror i can still see them :?:
i have tried typing(as root) get off my hard drive you son of a bitch :!: and there they still are :?
i have tried playing velvet revolver(quite loud too) but still they are there :?:
is there anything i can do to get rid of them(other than a re-install)??
or do i have to go outside and find some suitable birching sticks and thrash it to winthin an inch of it's life :?: :roll: 8) :D
paul
1slipperyfish
Forum Jester
Postby Rhakios » Mon Jul 25, 2005 8:02 pm
As root:
rm -rf /opt/java
rm -rf /usr/java
horrible way to treat a filesystem, but it's your installation. :shock:
Postby A-Wing » Mon Jul 25, 2005 8:17 pm
just don't call a file you need '-rf' :)
A-Wing
Postby Guest » Mon Jul 25, 2005 9:46 pm
thanks ever so :D
i will begin the install tommorrow night 8)
what does the rf do? is it remove file?
paul
Postby A-Wing » Mon Jul 25, 2005 10:04 pm
r = recursive
f = force (don't ask for y/n)
A-Wing
Postby 1slipperyfish » Tue Jul 26, 2005 8:03 pm
i have done it!!!!! :D
thanks to both of you for your time :D
want to share anything :?: 8)
i am off to watch bad girls to celebrate :D
paul
1slipperyfish
Forum Jester
Postby Rhakios » Tue Jul 26, 2005 8:43 pm
1
2
3
4
5
6
7
8
9
10
Phew! I did it, I managed to resist the temptation to make any sarky comments about 1sf (troll)'s post.
:D
Postby nelz » Tue Jul 26, 2005 9:15 pm
There's nothing wrong with watching bad girls Rhakios...
On the other hand, anyone watching Bad Girls needs serious help :lol:
Postby A-Wing » Tue Jul 26, 2005 9:59 pm
Bad Girls, isn't that somthing on one of those premium channels on sky? Not that I have ever seen those....I'll end this here :)
A-Wing
Postby Rhakios » Tue Jul 26, 2005 11:02 pm
After 1sf (troll) has been telling us about his career in porno, over on the PCPlus forums, I had to practise all the restraint I posess.
:D
Postby 1slipperyfish » Wed Jul 27, 2005 4:12 pm
i am a serious actor who got my first break in jaws as an extra
i've just fallen on hard times :D
why is your address not the one of the forum nelz?
bad girls is the best program on the telly in my opinion :!: and a real life potrayal of the issues that these women face :roll:
paul
1slipperyfish
Forum Jester
Users browsing this forum: Google [Bot], Yahoo [Bot] and 3 guests
