All in one Motherboard
Postby icrowe » Sat Jul 23, 2005 12:19 pm
I'm looking to build a Mandriva 2005LE based system by upgrading an old system. I have 2x30Gb HDD, optical drives, case, PSU (400W) etc. Can anyone recomend/warn me away from any all in one boards. I was looking for something which I could upgrade later. Probably a socket 754 board/Sempron with 512Gb memory and an AGP socket but also onboard graphics/sound/lan to keep initial costs down. The system will be used mainly for web browsing, coding and word processing, therefore high end 3D graphics not required. It would be nice if it would all be supported straight out of the box.
Any suggestions guys?
icrowe
RE: All in one Motherboard
Postby AJB2K3 » Sat Jul 23, 2005 3:29 pm
buy a via series MB from www.mini-itx.com all you need to add is a case, ram, and a dvdrw
AJB2K3
Postby A-Wing » Sat Jul 23, 2005 6:53 pm
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby nordle » Sat Jul 23, 2005 9:26 pm
itx is pretty expensive, a 939 venice with cool n quiet enabled in 2.6 kernel will run very cool, I can stop the fan completely as it sits at 34c
Sapphire ATI Radeon Xpress 200P SKT939 mATX w/LAN 6Channel Audio USB2.0 SATA £48
http://tinyurl.com/8j29m
AMD (Venice) Athlon 64Bit 3000+ Socket 939pin 512k L2cache 90nm Retail Boxed £100
http://tinyurl.com/89yax
Corsair (VS1GBKIT400C3) 1024MB (2 x 512MB Matched Pair), DDR400 / PC3200, non-ECC, Unbuffered, CL3, Memory Modules With Lifetime Warranty £60
http://tinyurl.com/ve02
Or if you only need 512MB, then its £32
Total = approx £210 / £180
nordle
