To Ghost or not to Ghost
Postby tedius » Mon Jul 18, 2005 3:04 pm
Just a guestion really.
What is the difference if I tar a drive with
tar cvjf /mnt/hda1/hda2.tar.bz2 *
and using partimage to take an image of the partion?
Is partimage better and if so why?
tedius
RE: To Ghost or not to Ghost
Postby nelz » Mon Jul 18, 2005 3:25 pm
tar will archive a directory and all below it including data on other filesystems (unless you use -l), partimage will archive the filesystem. Partimage should also be faster as it works at block level. The main disadvantage of partimage (IMO) is that you cannot extract individual files from the backup, it has to be extracted to a partition.
Postby hyperdaz » Tue Jul 19, 2005 11:04 am
its interesting that ya never said to To partimage or not to partimage instead of ghost....
To be honest I have never really trusted partimage...
on the second note...
Is there no partimage explorer like with ghost??
hyperdaz
Postby nelz » Tue Jul 19, 2005 11:17 am
Why not? It's worked well for me and never given a problem. As with any backup program, you should do a test restore, but I've never seen either that or a real restore fail.
