Why do you like your Graphics Card ?
PostPosted: Fri Jul 15, 2005 12:08 pm    Post subject: Why do you like your Graphics Card ? Reply with quote
Gotta get a decent graphics card ... but don't know really what to get (grin).
So i thought i might draw on some LXF experiance.
My existing setup so far is an ...
Athlon64 S939 3000+ with an Asus A8V-D board using the via K8T800Pro and via VT8237 chipsets and 1Gb of Geil. as dual 500Mb modules. Running deb.
Trying to decide on something around the 128Mb range, 3D capable. But it doesnt have to be fasted card around. Something mid-range, that will play a dvd properly and wont make me look like to much of a dork to my nephew (8y) (grin)
TIA
Nobber
PostPosted: Fri Jul 15, 2005 2:02 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
Can't go wrong with NVIDIA - their drivers are pretty solid. Only drawback is that they're not open source. Unfortunately, X11, decent 3D acceleration and open source don't seem to mix. Sad
PostPosted: Fri Jul 15, 2005 2:28 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
what he said Wink
mugstar
PostPosted: Fri Jul 15, 2005 2:59 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
Pretty much. Set a maximum amount to spend, then buy the best NVIDIA card you can get for the money.
bigbee
PostPosted: Fri Jul 15, 2005 3:54 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
I have a nvidia card and must say installation under suse went veryyyy smooth! Although installation on other distro's isn't that hard either...
If I was you, I would buy the best NVIDIA card I could afford (and that is compatible with my hardware ofcourse Wink )
Flea
PostPosted: Fri Jul 15, 2005 4:25 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
lol pretty unanimous isn't it. Very Happy You can add my vote to an NVIDIA card.
Dave
Gordon
PostPosted: Fri Jul 15, 2005 7:32 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
Get the best nVidia based card you can afford and get the Linux drivers from nVidia.com
View user's profile Send private message Yahoo Messenger
PostPosted: Fri Jul 15, 2005 7:33 pm    Post subject: RE: Why do you like your Graphics Card ? Reply with quote
I think NVIDIA cards are quite good, has anyone mentioned that? <insert innocent smiley here>
1slipperyfish
Forum Jester
PostPosted: Fri Jul 15, 2005 7:45 pm    Post subject: Reply with quote
what about NVIDIA cards Confused are they any good or what Question
paul
A-Wing
PostPosted: Fri Jul 15, 2005 10:27 pm    Post subject: Reply with quote
paul
Get an ATI, try getting it working in Linux, cry a bit, then you will get the picture Smile
Andrew Hutchings, Linux Jedi
www.a-wing.co.uk
View user's profile Send private message Visit poster's website MSN Messenger
dapo
PostPosted: Sat Jul 16, 2005 12:52 am    Post subject: Reply with quote
I would suggest a card that has been around for a few months, so that NVIDIA have incorporated support into their driver. If you are shopping in the sensible price range, I would expect all of the cards to be supported.
PostPosted: Sat Jul 16, 2005 12:00 pm    Post subject: Reply with quote
hmmmmm, ok, thanks for all that. I think i get the drift Very Happy
Nvidia it shall be, i actually feel a bad in a way too, to even think it (grin)
A-Wing
Some one must be a mind reader Smile.
Amongst Nvidia chipsets, is there much variance between the different vendors. I expect there would, board layout and cooling strategies would have some significance.
Ive been looking at linuxquestions.org lately ... and going over some of their reviews, which can be quite good, but tend to boil down to ... it either worked or it didn't, or it ... was recognised or it wasn't ... not much more detail than that. I'm wondering, does passive cooling actually work. It's cold over in Aus at the moment, but, when summer comes ... look out !, mega humid and mega hot.
Aside from memory, cooling, and layout, i guess the rest would involve ... what can be plugged into it, hmmm, i'll spend the next few weeks probing into Nvidia based cards i think. There are some markets on in town tomorrow, so i'll go and do some pricing there. I gotta get one of those mini PS/2 dust proff keyboards they have ... at $15, a bargain Smile.
dapo
Yes, a good suggestion.
http://counter.li.org
nordle
PostPosted: Sat Jul 16, 2005 4:49 pm    Post subject: Reply with quote
Is performance an issue? For example, some of the nvidia 6000GT offer very good value for money, but some have no active cooling which may be a real advantage
eg
Leadtek Winfast Geforce 6600GT 128MB Ddr3 AGP Dvi-i Tv-out Retail £120
http://tinyurl.com/92f9p
OR the slightly slower, but still pretty quick, silent
Gigabyte GV-N66256DP 6600 256MB Silent pipe AGP £90
http://tinyurl.com/8vqut
Dont know if anyone else thinks that these are not good anymore etc Or if there is better value to be had elsewhere etc
I think, therefore I compile
PostPosted: Wed Jul 20, 2005 10:29 am    Post subject: Reply with quote
Not necessarily, somewhere midway i guess. Not on a gaming crew level anyway (grin). I will be giving myself some time there, so it should workout. If it can play StarTrek dvds', as such, i'll be happy. I think cooling is though. Over here it gets quite humid during summer. Which tends to work against things. I can remember you mentioning Leadtek Winfast Geforce before, so i will take note of that.
nvidia cirtainly is a popular chipset, Thanks for all that, will note Smile
