Xorg Transparency Problem
Postby comcamel » Fri Jul 15, 2005 9:28 am
Well i have been trying to get transparency to work in KDE which i have recently seen in the new magazine which i have bought. After figuring out, that i had put the section in the wrong place, xorg has had problems with it.
Section "Extensions" Option "Composite" "Enable" EndSection
this is the command i mean. When i boot up, i cannot start up the X server, but when i access my logs for it gives the output of sasying something on the lines that it cannot find or doesn't see the extension. I have got Suse 9.3 with the nvidia driver, but i don't suppose i would have to download any extensions or library files, aswell as me typing it in wrong.
Currently i am on holiday and i don't have freqeuent internet access. However i am currently trying to relieve and try again...
Hope you can help thanks comcamel
comcamel
RE: Xorg Transparency Problem
Postby graham » Fri Jul 15, 2005 10:00 am
Your extensions part looks good. This works for me:
  Option "RENDER"         "Enable"
EndSection
But! You also need to add a couple of lines to the Device section for the nvidia driver. Mine reads:
Option  "RenderAccel"   "true"
Option  "AllowGLXWithComposite" "true"
My Device section looks like this:
Section "Device"
  BoardName    "GeForce 6600/GeForce 6600 GT"
  BusID        "1:0:0"
  Driver       "nvidia"
  Identifier   "Device[0]"
  Screen       0
  Option       "Rotate" "off"
  VendorName   "NVidia"
  Option       "NvAGP"  "1"
EndSection
Hope that helps!
graham
Postby comcamel » Sat Jul 16, 2005 10:17 pm
i have solved the problem, as looking finally when i had chance, i needed to install the composite manager rpm, which is a bit dodgy as i would expect to be installed. Now i have to sort out the speed issues. As it is slow...
this is the code piece i have seen on the internet that will improve speed like you posted, however i didn't know you had to put in the render option line, however since i have got an nvidia card i will find your details, useful! Thanks for the help that will be useful later!
comcamel
comcamel
