KDE just seems to hang! [SOLVED]
Postby percyt » Tue Jul 12, 2005 11:46 pm
Right - got the xorgconfig setup correctly and startx gave me a few shell screens so I went onto installing KDE.
As the magazine says I ran:-
emerge kde -av (which took forever!!!)
then updated /etc/rc.conf to include kdm for the display manager
then
rc-update add xdm default
to run on boot up.
Rebooted the pc and it went straight into kde, asked me for a login and then popped up this window:-
Session Menu
chooseSessionListWidget
Load Session | Delete Session | Break Lock | Default/Fail Safe | Cancel
The only options are default/fail safe and cancel - cancel takes me back to the login and default/fail safe clears this window and then does nothing.
There's no hard disk movemen, nothing! The mouse still moves but no key presses, mouse clicks do anything - I have to physically power it off and then back on.
Any ideas?
TIA
percyt
RE: KDE just seems to hang!
Postby nelz » Mon Jul 18, 2005 12:16 pm
Did you put
XSESSION="kde"
in /etc/rc.conf? If not, you may need to select a session type fro the KDE login window. It looks like it may be complaining that you haven't selected a session.
Postby percyt » Mon Jul 18, 2005 1:40 pm
Right - I need to look at that but as all the screen displays now is a flashing low-res desktop I can't get onto the pc.
I can't CTRL ALT F'anything' to get to another desktop as it just won't do anything!!
Is there a way of crashing out of KDE?
percyt
Postby nelz » Mon Jul 18, 2005 2:54 pm
Add
softlevel=single
to your kernel line in GRUB (press e to edit it, make the changes then press b to boot it). That will start you without X. then do
rc-update del xdm
to prevent X starting on bootup.
You really shouldn't have added xdm to the default runlevel until you had tested it, but I guess you've realised that now :)
Re: KDE just seems to hang!
Postby davecs » Mon Jul 18, 2005 3:24 pm
percyt wrote:The mouse still moves but no key presses, mouse clicks do anything - I have to physically power it off and then back on.
Any ideas?
TIA
I take it you have a 3D system like nvidia or ati. Search the net, you will find loads about it. I myself started a thread on it here:
http://linuxformat.co.uk/index.php?name=PNphpBB2&file=viewtopic&t=301
The really weird thing is that I rebuilt the same componenets onto a different motherboard and it stopped!
If you are using nvidia graphics, and you don't actually need 3D acceleration, change the video driver from "nvidia" to "nv" in the file "/etc/X11/xorg.conf".
When the freeze occurs, try this:
Holding down ALT and SYSRQ, press in turn, with a few seconds wait, S, U and B. If your kernel has "Magic SysRq" enabled, it won't prevent a reboot, but at least it will be a clean reboot.
ALT+SYSRQ+S = Synchronise Disks
ALT+SYSRQ+U = Unmount Disks
ALT+SYSRQ+B = Reboot.
Hope this helps.
davecs
RE: Re: KDE just seems to hang!
Postby percyt » Tue Jul 19, 2005 3:10 pm
Managed to get to rc.conf and amend it - it works ok now!!
Now I want to do a fresh install of 3.4 - but i'll start another thread.
percyt
