"Ghosting" Linux
Postby A-Wing » Mon Jul 18, 2005 12:14 pm
nelz wrote:
A-Wing wrote:You ever tried to cp a /dev directory? or any virtual sockets?
cp -x will fix that, copying it if it is static and skipping it if it is handled dynamically by devfs or udev.
True, I'm thinking scp for some reason, which is a pain in the arse to copy stuff with dev directories in without taring first, I'm doing far to much ssh work lately.
Although I don't believe scp will copy the bootsector so you would need to reinstall grub/lilo
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby Nobber » Mon Jul 18, 2005 1:14 pm
cp is also good for copying entire partitions. Many's the time I've done a
1. cp /dev/hdaX /somewhere/on/2nd/hdd/hdaX.img
2. repartition /dev/hda
3. mount hdaX.img /source -o loop
4. mount /dev/hdaY /target
5. cp -a /source/* /target
just for a laugh (or even seriously).
Nobber
GNU OpenSource Ghosting Cloning and Imaging with Linux
Postby CoolAJ86 » Mon Aug 01, 2005 11:17 am
In the gentoo wiki there is a little repository of such guides.
http://gentoo-wiki.com/OpenSource_Ghost ... ing_Guides
CoolAJ86
