Linux on windows Vertual pc
Goto page Previous  1, 2, 3
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS
PostPosted: Sat Sep 22, 2007 9:50 pm    Post subject: Re: RE: Re: Microsoft VPC Linux support... Reply with quote
phil1ooo wrote:
sled came in vmware tools,You know I haven't been able to do anything on this so called great linux system due to this fact,,I installed Suse in vmware it then told me I had to install vmware tools .
And as I said you install tools for windows not linux as that the environment your running vm from.
phil1ooo
PostPosted: Sat Sep 22, 2007 11:45 pm    Post subject: Re: RE: Re: Microsoft VPC Linux support... Reply with quote
[And as I said you install tools for windows not linux as that the environment your running vm from.[/quote]
OK the vmware tools I downloaded came from the vmware toolbar and I have gone and looked for other vmware tools independently but it just reverts me bact to this one.
PAUL mate:,you go right ahead a give me that headache if you think your good enough to help solve this problem as I don't get insulted or affended by a few words,herd it all before so bring it on mate your more than welcome i'm all ears and it would be very much appreciated beleive me.
As for you others that just agree with him and nothing else,get a life.
PostPosted: Sun Sep 23, 2007 10:56 am    Post subject: RE: Re: RE: Re: Microsoft VPC Linux support... Reply with quote
Phil1ooo:
Sorry, 1sf (troll) is the Linuxformat resident threadjacker, just ignore him (and the banter that he attracts Wink
Installing applications in Linux is actually easier than Windows, as long as you use the package manager for your distro .
Microsoft (and others) tried to get people to install stuff using the add/remove programs install manager, but most people and most software just ignore it.
On Linux, that is not an option.
I have seen the advice given you on another thread about this link.
follow it carefully and it will help.
.rpm files are not .exe files or whatever, they are packages of files and settings that need to be read and installed using a package manager. YAST (Yet Another Setup Tool). is the Suse version of the control panel in Windows.
Suse 10.1 actually has the install process locked down a bit too tight, 10.2 is much better ( I use it all the time).
One way around the repository problem, if you can't find the .rpm that you want in one, is to make a local folder for .rpms, and add that to yast as a repository.
I am sure when you get to know your way around, you will be fine.Smile
PostPosted: Sun Sep 23, 2007 11:13 am    Post subject: RE: Re: RE: Re: Microsoft VPC Linux support... Reply with quote
Have you tried this? is this where you get permission denied?
Quote:
The installers for VMware Tools for Windows, Linux, FreeBSD, Solaris, and NetWare
guest operating systems are installed with VMware Workstation as ISO image files.
When you choose VM>Install VMware Tools from the VMware Workstation menu
bar, Workstation temporarily connects the virtual machine’s first virtual CD‐ROM drive
to the correct ISO image file for the guest operating system. You are ready to begin the
installation process.
You can use this menu command to either install or upgrade VMware Tools. On
Windows and Linux guests, you can also set VMware Tools to perform automatic
updates, as described in the next section, “Upgrading VMware Tools” on page 116.
1slipperyfish
Forum Jester
PostPosted: Sun Sep 23, 2007 4:02 pm    Post subject: Reply with quote
Confused Confused Confused
you seem to as i was agreeing with you and you're arguing with me??????
paul
PostPosted: Tue Sep 25, 2007 1:45 pm    Post subject: Re: RE: Re: Microsoft VPC Linux support... Reply with quote
VMware-tools is installed in the guest operating system, so the Linux version is correct. However, despite what VMware tell you, it is not required. I run several Linux guest OSes without vmware-tools installed.
However, phil1ooo, you are going to have to recognise that this is a peer support forums where abuse of those trying to help is even less welcome than on a paid support line. Don't expect the people you are abusing to go out of their way to help you.
PostPosted: Tue Sep 25, 2007 11:00 pm    Post subject: Re: RE: Re: Microsoft VPC Linux support... Reply with quote
I'll stand corrected, it a while since I installed Linux into a VM and I'm sure it was an exe that loaded the tools, ah well the grey cells dying off.
I think I also said they where not needed too.
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS All times are GMT
Page 3 of 3
