make install
make install
Postby richardclaxton » Wed Jul 06, 2005 12:00 pm
I have just started to build applications from the source. All seems ok using the 3 steps of ./configure, make, make install.
After the make install should the app be in /usr/bin or is this dependant on params past to it ? as the new app seems to be in /bin of the new app source directory tree, i though it should have been moved to /usr/bin ?
For example building a newer version of autoMake the new version does not get moved to usr/bin
richardclaxton
RE: make install
Postby A-Wing » Wed Jul 06, 2005 12:23 pm
Default is usually /usr/local/bin for most apps. If you want to set it differently you should do it in the ./configure stage. A typical setup is:
./configure --prefix=/usr --localstatedir=/var --sysconfdir=/etc
./configure --help should give you a full list of options to use
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Users browsing this forum: Google [Bot], Yahoo [Bot] and 2 guests
