Announcement, Project based on CentOS
Postby tronn » Mon Sep 03, 2007 5:10 pm
I put together a CD with Open-exchange 0.8.6-5/0.8.7-0 and more, based on Centos 4.4
When installing the CD, all required software is installed, all that is needed after Os install is to run a config script, that make if fit your environment
Depending on the speed on your CDrom the installation should take no more than 30 minutes
It install the following:
* Open-Exchange 0.8.6-5/0.8.7-0 you choose which one
* Samba PDC
* A PDF printer
* Wildfire, a jabber server (for chating )
* Avaadm
* Jetti, (jabber webclient)
* Squid
* Nameserver ( needed when join machins to domain)
* Smartsive and websive
* Antivirus
* Syncml ( but i havent got it to work with any of my clients )
Since it could be so difficult to install, I put this together CD, and I guess also others would find some use for it
Its available for download here http://www.nnortux.no
Tronn
tronn
Return to Announcements
