j2sdk not included -gentoo dvd version
Postby niceguy » Fri Jul 01, 2005 11:43 am
Hi all
this is my first post after joining, looks like a great place to be :) . I am at the "emerge" stage of gentoo using the dvd from LXF68 and all has gone well till I received this message
js2dk-1-4-2-doc-zip not found in /usr/portage/distfiles
And I am being asked to download it manually and I cannot find it on the dvd. So am stuck. Anyone with this problem?help. :?:
niceguy
RE: j2sdk not included -gentoo dvd version
Postby nelz » Fri Jul 01, 2005 12:07 pm
Sun's licencing makes distributing the SDK difficult. Gentoo have the same problem with including it ino their mirror, hence the message. You can either download it manually and copy it to /mnt/gentoo/usr/portage/dsitfiles, or put -java in the USE flags in /etc/make.conf to install without Java.
Postby niceguy » Fri Jul 01, 2005 12:18 pm
Thanks for such a speedy reply!Checking it out now :lol:
niceguy
Return to This Website
