dvd writing?
Postby 1slipperyfish » Sat Jul 02, 2005 9:16 am
sorry that was me :roll:
i just burned them in wndows so it wasn't a problem although k3b was hard work :x as i said i burned the kanotix iso and when i tried to boot it, it didn't work when i put the disk in in windows it had called the disc k3b but hadn't written any data to it :? as it had claimed :?
paul
1slipperyfish
Forum Jester
Postby Rhakios » Sat Jul 02, 2005 10:02 am
In K3b did you use Tools>Burn CD Image ?
Postby 1slipperyfish » Sat Jul 02, 2005 10:06 am
yes then it had two bars of green lights and after about two minutes it went da-da!! you were successful, but it just burned the title k3b to the disk :roll:
if i wanted to could i tamper with the code? as i'm a bit unsure of legalities is it that you can alter code as long as you publish what you have done?
paul
1slipperyfish
Forum Jester
Postby Rhakios » Sat Jul 02, 2005 10:12 am
You can tamper with the code for K3b as much as you like, and if you improve it you can pass your patches back to the developers. However, I think you will find that Mandriva does not use the latest version 0f K3b, it is always in development, so if you want to work on it you ought to get the latest from their svn http://www.k3b.org/
Postby 1slipperyfish » Sat Jul 02, 2005 10:17 am
i just looked and the downloads are for kde3.1 and 3.2 not 3.3? will mine not be newer or the same as these?
paul
1slipperyfish
Forum Jester
Postby Rhakios » Sat Jul 02, 2005 10:23 am
None of them. Click on the + sign next to downloads, then click on SVN, it tells you how to download the latest source there.
Postby 1slipperyfish » Sat Jul 02, 2005 10:35 am
thanks :D
paul
1slipperyfish
Forum Jester
