Can't execute slamdunk.exe. Please help!!!
Postby AlleyCat » Thu Jun 30, 2005 2:28 pm
I downloaded a file called slamdunk.exe form www.slamdunk.com, but I am unable getting it running on my brand new Linspire distro. It says something about not recognizing the format. Please help!!!!!!
AlleyCat
RE: Can
Postby Nobber » Thu Jun 30, 2005 3:17 pm
Going out on a limb and thinking outside the box here, but my guess is that slamdunk.exe is a Windows executable. For Windows.
Nobber
RE: Can
Postby towy71 » Thu Jun 30, 2005 3:38 pm
AlleyCat you is beyond help here :D :D :D
RE: Can
Postby Flea » Thu Jun 30, 2005 6:38 pm
Alleycat Slamdunk.exe is probably a windows program, in order to run windows executables with Linux you will need to install Wine (www.winehq.com) Even then you may be out of luck, it can be tricky convincing some applications to run under Wine.
Dave
The question is, who cares?
Flea
Postby 1slipperyfish » Thu Jun 30, 2005 8:03 pm
could you not run it as a c++ app???
paul
1slipperyfish
Forum Jester
Postby M0PHP » Thu Jun 30, 2005 8:30 pm
1slipperyfish (troll) wrote:could you not run it as a c++ app???
paul
What?!? :shock: :roll:
M0PHP
Postby Flea » Thu Jun 30, 2005 8:37 pm
paul
If the sourcecode is available then it could be ported, but Its probably closed source. AlleyCat - why don't you email the developers and request a linux version? If they knew there is a demand for a Linux version they may (if you got high in the sky apple pie hopes) release a port :)
Dave.
Flea
Postby 1slipperyfish » Fri Jul 01, 2005 12:56 pm
i was only asking :roll: i compiled and ran some simple c++ code to answer a question in the prog. section and it made an .exe file which is now in /home/paul, i just thought(it seems wrongly :roll: ) that if i can run this .exe file from konsole then perhaps AlleyCat could.
paul
1slipperyfish
Forum Jester
Postby Flea » Fri Jul 01, 2005 2:16 pm
huh? Seems a little odd that it would be given an .exe extension. What compiler are you using? If it was gcc are you specifying an .exe extension when compiling? for example - gcc program.c -o program.exe
Flea
Postby 1slipperyfish » Fri Jul 01, 2005 2:33 pm
no i just used g++ -o hello hello.cpp and i've got an icon of a piece of paper with a green circle on it called hello.cpp and a blue cog called hello.exe?
paul
1slipperyfish
Forum Jester
Postby Flea » Fri Jul 01, 2005 2:42 pm
ok... freaky... I have absolutely no idea why it would do that?! Addmitedly I don't do much programing anymore these days but Iv never seen gcc/g++ do that before lol :shock:
I just had to compile a little test program now to see if I got the same -
dave@crusader:~$ g++ -o helloworld helloworld.cpp
I just got a file called "helloworld" no extension at all. If I don't specify an output file I get a file called "a.out". :?
Flea
Postby 1slipperyfish » Fri Jul 01, 2005 2:46 pm
aparently that is one of the faults with the gcc compiler that if you don't specify an output you get a.out
which is ok if you only have one but if you had ten it might start to get confusing :D
paul
1slipperyfish
Forum Jester
Postby Nigel » Fri Jul 01, 2005 6:42 pm
1slipperyfish (troll) wrote:aparently that is one of the faults with the gcc compiler that if you don't specify an output you get a.out
paul
That's been a "feature" of UNIX compilers ever since I can remember... IIRC the Pascal compiler on the first Unix box I used back in 1982 used to do it.
gcc is just keeping up a fine tradition :D
Postby 1slipperyfish » Fri Jul 01, 2005 10:43 pm
aha! as i said :roll:
paul
1slipperyfish
Forum Jester
Postby Nigel » Sat Jul 02, 2005 10:54 am
The thing is, your (well, most people's) typical program will consist of more than one source file. So what name is the linker (final stage of gcc) supposed to use if you don't tell it ?
At least a.out is easy to find in a directory full of source, include & object files, which is probably why it was chosen.
