Midi Keyboard
Midi Keyboard
Postby Stingray » Mon Jun 27, 2005 5:43 am
Hi all
does anyone know of a good audio editing package that allows you to play a midi keyboard. I dont want a too complicated program just one that allows me to play my midi keyboard through my pc with good quality sound
Sting
Stingray
RE: Midi Keyboard
Postby davecs » Mon Jun 27, 2005 9:52 pm
Having just got a new mobo, I found that it has a header onboard to connect to a MIDI keyboard. I also have a keyboard and a lead! What I can't ******* get is the header to backplate lead for the computer!!
Anyway, I intend to try Rosegarden when I've got it all connected.
davecs
RE: Midi Keyboard
Postby zarathustra » Mon Jun 27, 2005 9:54 pm
There is one, I can't recall it atm, but I'll go looking in the attic tomorrow for my old SuSE manuals as I know it was mentioned in there. That's a bit of a downer I grant because you may need to wait, but the upside is it was on SuSE 7.2 so the app if still around will have been polished a little by now.
regards Zara...
zarathustra
RE: Midi Keyboard
Postby Nigel » Tue Jun 28, 2005 8:35 am
The SuSE 8.2 manuals say you need a package called pmidi to link your midi port into the ALSA sound system. You should then be able to use kaconnect to link that to your soundcard, recording app or whatever.
It doesn't go into a lot of detail - IIRC the SuSE 7.2 manuals had more info.
RE: Midi Keyboard
Postby Rhakios » Tue Jun 28, 2005 6:47 pm
I have the three SuSE 7.2 manuals here and I can't find anything about configuring midi specifically in any of them. In section 10.3 there is an extensive section on kernel module parameters for particular chipsets, but other than the use YaST bit, that's about all there is.
Edit: Silly me, did I say three manuals, I meant five :shock:
RE: Midi Keyboard
Postby zarathustra » Wed Jun 29, 2005 6:38 pm
Hi, sorry for delay,
I have checked my "five manuals" as well, the one entitled applications has a section on Multimedia. In it Midi is well covered in an introductory sense and then some, up to you to read individual app manuals *sigh if your heart just sank so did mine* a few apps stand out first Rosegarden, second Jazz and Kmidi. how good they are remains to be seen as 7.2 is rather old, but I always liked it :)
The section is not short on further reading, in fact after reading chapter five which introduces MIDI from many angles through the apps which rely on it, you'll have no shortage of avenues to explore.
Unfortunately it will require a little learning on your part, but then if you're really interested in midi it should be a joy :)
Please post back with any success you have as I too am interested before going out and buying a midi keyboard *duck*
Oh and let this be an example of how SuSE manuals rock ie they are informative and stand the test of time rather well.
regards Zara...
zarathustra
RE: Midi Keyboard
Postby Rhakios » Wed Jun 29, 2005 7:44 pm
That's what I get for looking in the Index (where midi, sound and audio don't get a mention) rather than the Contents. Ho hum.
play texas holdem online free
Postby otard2914@yahoo.com » Thu Jul 07, 2005 5:06 pm
In your free time, check out some information ontexas holdem poker demo online
otard2914@yahoo.com
RE: play texas holdem online free
Postby evilnick » Thu Jul 07, 2005 5:31 pm
Gee, does anyone know where I can play poker?
Oh, and by the way retard2914, you don't want a lot of militant Linux cognescenti on your ass, so I suggest you move your message spam elsewhere...
evilnick
