Damn Small Linux on Dell Latitude D610
Postby Guest » Fri Jun 24, 2005 10:16 am
Background:
I have a laptop from work which runs a locked down XP and work rules preclude installing anything on it anyway. It would be nice to run what I want from a USB key. From your recent roundup Damn Small Linux looks good.
The problem:
I have downloaded and burnt two CD images dsl-1.2.iso, dsl-1.2-syslinux.iso.
Both CDs are bootable and contain KNOPPIX, lost+found and index.html files and folders. One also has a boot folder.
If I boot off the CD with the boot folder then no matter what options I select I see the start of the kernel loading (2.4.26) and then the screen goes blank and the machine locks solid. Power off/on and repeat.
The second CD fails in a similar way except that the failsafe option works. However the failsafe option disables useful things like USB support (see 'background').
I looked in the boot older and found an isolinux folder containing (amongs other files) isolinux.cfg. This appeared to include the options used for a failsafe boot (nousb nofirewire noagp, etc.) so I tried that with the other CD but it always locked up. (I thought I could start with a successful boot and then remove options until I isolated the problem and had USB working).
For reference Knoppix 3.8.2 runs vanilla straight from the CD (but is a bit big for my USB key).
I have looked in linux-laptops.org but I haven't found anything relevant so I am open to any ideas (or alternatives) so that I can install linux on a USB key and run it on this machine with support for ethernet, wireless and as much else as is possible.
Thanks for any advice.
RE: Damn Small Linux on Dell Latitude D610
Postby fingers99 » Fri Jun 24, 2005 5:29 pm
I think you can use the Knoppix "cheatcodes" with DSL (which is Knoppix based, anyway).
So, at boot you'd enter "noagp" so you saw:
boot: noagp
But you'll get a quicker answer on the DSL or Knoppix forums.
fingers99
Postby Guest » Sat Jun 25, 2005 5:30 pm
Thanks but, as I said, I tried the cheatcodes that were included with the isolinux.cfg 'failsafe' option. I even added a few such as noapic noapm but it still locked up. I will check to see if there are many more.
Postby fingers99 » Mon Jun 27, 2005 9:39 pm
OK, but you only tried the bootcodes included in the failsafe option: there may be others.
The DSL forum is here while the Knoppix one is here.
fingers99
Postby Guest » Wed Jun 29, 2005 9:07 am
Sorted! A strange thing. Of the two CDs the only one that would boot cleanly was the non-syslinux one and that only with the failsafe option. No assortment of command line options would work on that CD.
However after wasting a lot of time I decided to give the syslinux CD another go with my new array of command line options - and it worked. I eventually whittled the dozen or so options down to 'acpi=off'!
That still doesn't work on the non-syslinux CD but it works a treat with the syslinux one. Early success suckered me into relying on the wrong CD!
Moving on . . . .
Users browsing this forum: Alex01UK and 3 guests
