New distro-doesn't detect anything
Goto page 1, 2  Next
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS
PostPosted: Thu Mar 29, 2007 10:17 pm    Post subject: New distro-doesn't detect anything Reply with quote
Hi, I decided to install a new distro today( a reinstall on a new HDD actually, but I decided to start from scratch)
Booted from the CD, partitioned the first 30Gb, ran through the install, and it booted into the window manager, wouldn't join a domain,
Failed to detect my hardware. as follows:
Network card, standard Intel 100mbit
video card, ATI rage
Sound card- ac97
wifi card-cisco
USB hub
Unknown device (think that is the Mobo IDE chipset)
Trackpoint device
and it installed no applications at all!
(What was this distro?- Windows XP professional - no network card meant no downloads, no drivers, no activation.etc.
This is on an IBM R40 laptop with "Windows XP recommended" sticker on it.
So- why are all these people complaining when Linux doesn't detect their hardware? This is a 2 year old windows recommended Laptop.
(For your information, SuSe 10.2 detects and installs ALL of these pieces of hardware perfectly).
I had to download the NIC driver on another PC and copy it across just to activate it!
risc_user
PostPosted: Fri Mar 30, 2007 12:48 am    Post subject: RE: New distro-doesn Reply with quote
I tried an old Windows distro a few weeks ago because a friend uses it and said it was really great and everything. So I downloaded a copy of "Windows 98" to see what the fuss was about.
Stuck it on a spare computer, it had to reboot loads of times for unknown reasons (it was in spanish because the ISO image was smaller for some reason) and it wouldn't use a resolution higher than 640x480 with the same monitor that Ubuntu can get 1280x1024 out of.
The network card was recognised on mine, well, it said it found a network card. It didn't have a driver for it though.
USB didn't work. So I went to the Dell website (it being a Dell an' all) and downloaded all the drivers for the USB and also the screen and network card. The drivers came in the form of scripts that run regardless of your permissions and they didn't work anyway. Windows 98 just keeled over and died.
So I wiped the hard drive and put Ubuntu back on it.
I can't see this "Windows" thing catching on you know. Just not ready for the desktop.
godofthedevil
PostPosted: Thu Apr 05, 2007 5:21 pm    Post subject: RE: New distro-doesn Reply with quote
windoze does distros?!
well i guess you have the 9x distro and the NT Distro..
i thought linux was the one who did "distros"
My Websites.
www.stewfisher.co.uk <- main one
www.shopforlinux.co.uk <- Linux CD shop
Be sure to check em out Smile
LinuxMint, The loveable Grandchild of Debian/GNU Linux
PostPosted: Thu Apr 05, 2007 9:40 pm    Post subject: Re: RE: New distro-doesn Reply with quote
It was meant to be sarcastic, I just get sick of all the idiots (and there do seem to be a lot of them) who say :
"I can reinstall windows in the time it takes me to make a cup of coffee" (that is actually a quote!) "and it does everything I want with no problems"
In other words, liars.
PostPosted: Thu Apr 05, 2007 9:42 pm    Post subject: RE: Re: RE: New distro-doesn Reply with quote
Perhaps they have to grow the beans, then harvest the beans, then roast the beans...
It might well do everything they want with no problems if they are quite undemanding.
godofthedevil
PostPosted: Thu Apr 05, 2007 9:47 pm    Post subject: RE: Re: RE: New distro-doesn Reply with quote
well according to my mcdst course you can install serval xp machines while making the coffee and it pretty much sorts its self out..
mandriva IMHO is the quickist installing
it takes me a weekend to set up an xp machine up to a state that is workable that is all the 3rd party drivers n software.. most of that is the waiting game
My Websites.
PostPosted: Thu Apr 05, 2007 10:08 pm    Post subject: RE: Re: RE: New distro-doesn Reply with quote
The thing is that most Linux newbies complain when a particular distro doesn't install and configure all of their hardware.
In fact Windows doesn't do this, if you compare a Windows install and a Linux install on the same hardware, chances are that the Linux install will work with most stuff "out of the box", whereas a Windows install will need lots of configuration, driver installs, reboots, etc.
Windows doesn't do MP3 or Encrypted DVDs out of the box either.
In comparison mode. a recent install of 2 OSes on the same box took 14 reboots, 40 minutes configuration, and 12 CDs (including the XP one), and several downloads for Windows (not to mention several long hexadecimal codes), as opposed to 1 DVD, 15 minutes configuration, a couple of downloads, and 1 reboot for SuSe Linux, for a comparable installation.
The total install time for Windows was about 5 hours, compared to less than 3 for linux.
I just want people to compare like for like.
It is difficult, but I have excluded update times for the above, because they are so variable, but I find that Suse Linux updates again win, with less interaction, more explanation if you want it, and faster application, not to mention no reboots, and hence no down time!
P.s. My work WindowsSBS2003 server asks to reboot every time I run Updates, (and pesters me if I refuse) THIS IS A SERVER!I CAN'T JUST REBOOT ON A WHIM! GET REAL!
godofthedevil
PostPosted: Thu Apr 05, 2007 10:13 pm    Post subject: Reply with quote
oh i agree about (most) distros working more then windoze..
like divx movies you dont have to (normally) install a codec for it
but the fun of linux is to tweak and to get to know your computer.. i use gentoo and i admit its a bitch to install and get working but when you do, you can sit back and admire your handywork
My Websites.
PostPosted: Thu Apr 05, 2007 11:16 pm    Post subject: Reply with quote
How quickly you forget just how bad Win98 was. I changed the gateway address on a Win98 box this week and it had to reboot to update the routing!
PostPosted: Thu Apr 05, 2007 11:30 pm    Post subject: Reply with quote
routing in W98, that's just masochism
PostPosted: Thu Apr 05, 2007 11:41 pm    Post subject: Reply with quote
I had to try and fix somebody's [shudder]WinME[/shudder] box last week, I had to go and lie down in a darkened room to recover Confused
godofthedevil
PostPosted: Fri Apr 06, 2007 9:02 am    Post subject: Reply with quote
i have just changed the deck on solitaire. damn now i have to restart my computer
My Websites.
PostPosted: Fri Apr 06, 2007 10:28 am    Post subject: Reply with quote
Now you're being silly. Microsoft would never cripple such important productivity software...
godofthedevil
PostPosted: Fri Apr 06, 2007 4:11 pm    Post subject: Reply with quote
i wouldnt put it past them..
no doubt you cant use it with out the WGA telling you no!
My Websites.
pootman
PostPosted: Fri Apr 13, 2007 1:42 pm    Post subject: Re: RE: New distro-doesn Reply with quote
A mis-quote i think, that should read:
"I have to reboot windows every time I make a cup of coffee and then it does everything I want with no problems"
Inspired by this thread I tried to install Win98 on spare-parts (nForce2/AthlonXP2500/1GB333DDR) last night. I lost count of the number of reboots, but after installing five or six sets of drivers it was, like the (occasionally spontaneous) reboots, fast.
I've cleansed the hd with 'mkreiserfs', but *I* still feel dirty.
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS All times are GMT
Goto page 1, 2  Next
Page 1 of 2
