Fdupes vs. whitespaces problem!
Discuss LXF Team Blog entries here
Postby Toallpointswest » Tue Mar 27, 2007 12:06 am
I've been trying the fdupes command from this months issue to find and delete duplicate files
fdupes --recurse --omitfirst <directory> |xargs rm
And every time it comes across a file or pathname with a whitespace in it I get the following error:
rm: cannot remove '<file or directory with whitespace>': No such file or directory
Any ideas how I can get this command to work properly? Thanks!
Toallpointswest
RE: Fdupes vs. whitespaces problem!
Postby Kev1729 » Tue Mar 27, 2007 12:57 am
If you use it with the --delete flag it works fine, else if you are using your own script (or indeed one that came with the mag, shows how much i read it) to delete the files you would need to escape the filenames first.
Kev1729
Postby nelz » Tue Mar 27, 2007 8:27 am
xargs doesn't handle filenames with spaces at all well. If you replace "| xargs rm" with
| while read f; do rm "$f"; done
your spaced put files should be deleted correctly.
Re: RE: Fdupes vs. whitespaces problem!
Postby Toallpointswest » Tue Mar 27, 2007 3:47 pm
nelz wrote:xargs doesn't handle filenames with spaces at all well. If you replace "| xargs rm" with
That did something, but now I get:
rm: cannot remove `':No such file or directory
So it looks like it didn't pass the variable correctly
Toallpointswest
RE: Re: RE: Fdupes vs. whitespaces problem!
Postby nelz » Tue Mar 27, 2007 3:53 pm
More likely that the variable contained something rm didn't like. It should have deleted everything up to the dodgy item, so try
fdupes --recurse --omitfirst <directory> | head
to see what comes next.
Postby Toallpointswest » Tue Mar 27, 2007 9:33 pm
Tried it on another directory, and I have the file list I expected, so I'll try it again.
EDIT: Okay tried it again and, it creates a listing of file names, with a blank line in between each line. I think that the error I'm seeing is rm trying to delete that blank line, as when I re-run fdupes on that directory it finds no dupes, so it is working.
Toallpointswest
Return to LXF Blog Comments
