Radeon 7000
Radeon 7000
Postby palepaul5 » Wed Jun 15, 2005 12:15 pm
Hi Nelz,
I remember in one of the past issues of LXF, someone wrote there was a Precision 530 with Radeon 7000 at 'LXF Towers'. My question is, if it is still there have you been able to get Mesa working properly on it. Ever since the fork in X I have been totally unable to get any proper 3d performance from it at all. I currently use the same set-up but no matter what I try I either get a complete lock-up or no performance at all. Any help on this matter would be gratefully received.
(Y) PJF (Y)
palepaul5
RE: Radeon 7000
Postby Guest » Thu Jun 30, 2005 12:50 pm
I had to disable the 3D acceleration to get my Mandriva 2005 LE installation to stop freezing up on me.
RE: Radeon 7000
Postby nelz » Thu Jun 30, 2005 2:24 pm
Don't ask me, I've never been to LXF Towers 8)
RE: Radeon 7000
Postby Nobber » Thu Jun 30, 2005 3:51 pm
This is me not asking nelz.
There.
Nobber
RE: Radeon 7000
Postby nelz » Thu Jun 30, 2005 8:48 pm
Where?
RE: Radeon 7000
Postby linuxgirlie » Thu Jun 30, 2005 8:52 pm
There on the stairs, a little mouse with clogs oooonnnnnnnn, well I dispear, going clip clippy clop on the stairs, right there, where?, yet there on the stairs..........
*sorry*..... :oops: :oops:
linuxgirlie
RE: Radeon 7000
Postby alloydog » Fri Jul 01, 2005 4:34 am
Dragging the post kicking screaming back on thread...
From what I gather, ATi Radeon, prior to the 8500 series are pretty hit and miss. They are supposed to be fairly fully supported in XFree86 from (IIRC) 4.1.0 onwards, with only a few bugs to do with dual heads, but hardware acceleration should be supported without problems. X.org, though still doesn't seem to support HW acceleration yet, but according to LXF 68, in the big article about X, it seems a major rewrite is coming and things like HW accelration, direct rendering, and other groovey terms I don't quite understand, will be supported, and much better.
I have an ATi Radeon 7500 64 MB card. Reading the man page for it and XFRee86 4.3.0, it should have HW acceleration up and running with just the lines:
Load "dri"
Load "glx"
to the Module section, and
Section "DRI"
Mode 0666
EndSection
to the end of XF86Config.
But, I tried to run one game (Boson) which complained that direct rendering wasn't enabled, and the game would run quite slow. 'Run' wasn't the word. A deathly crawl was more the result.
I don't know how to test to see if DRI is enabled without running something like a game that looks for it. Any ideas?
alloydog
Re: RE: Radeon 7000
Postby Nobber » Fri Jul 01, 2005 8:20 am
alloydog wrote:I don't know how to test to see if DRI is enabled without running something like a game that looks for it. Any ideas?
glxinfo | grep render
Nobber
RE: Re: RE: Radeon 7000
Postby alloydog » Fri Jul 01, 2005 9:54 am
Thanks, I have also just found this HOWTO: http://bluszcz.jabberpl.org/radeon_dri_howto.txt , but I haven't had time to try it out yet.
alloydog
Postby palepaul5 » Sat Jul 02, 2005 1:26 pm
I actually put MDK 10.1 back on to my box, and the card works a dream again - It must be the jump from 6.7 to 6.8 with Xorg that caused the problem(obviously...doh) I'm going to have a right good dig about between the two to see what seems to have broke. If I have any joy, I will post for others.
(Y) PJF (Y)
palepaul5
Postby alloydog » Sun Jul 03, 2005 6:26 am
Aha! X.org does not currently support hardware acceleration for a lot of cards, ATi Radeons often being the prime example.
alloydog
