Syncro Soft Announces a New Product: Syncro SVN Client.
Postby syncrosoft » Wed Jan 31, 2007 8:35 am
Syncro Soft Ltd, the producer of oXygen XML Editor, has announced the immediate availability of Syncro SVN Client, a platform-independent Subversion (SVN) client aimed at giving Subversion repository users a high quality user interface. Syncro SVN Client has been designed to offer powerful actions while keeping the interface as clean and as simple as possible.
Syncro SVN Client is released under the 2.0 version because it was initially developed as an embedded component in oXygen XML Editor and starting with version 8.1 of the editor it is available also as a separate product.
Syncro SVN Client makes easier the document and code sharing between content authors or developers. It offers full SVN repository support: checkout, export, import, copy, mkdir, rename, branch, tag and delete. The front-end allows you to browse repositories, check for changes, commit changes, update your working copy and examine the revision history. There is no need to install separate applications like a Subversion command line client or a file compare tool.
Syncro SVN Client is composed of several views allowing you to browse the Subversion repositories and your local working copies, compare and merge modifications, check the revision history. All the views are dockable, this means you can position them to create the optimal layout for your use case.
The Subversion Repository Browsing view allows you to add multiple SVN repositories to the list and browse them in parallel. In this way you can identify the resources you need to checkout, or even create branches or tags directly in the repository.
In the synchronize view you can see the overall status of your working copy resources when compared to the repository resources. The view focuses on incoming and outgoing changes, where incoming changes are the changes that other users have committed since you last updated your working copy. The outgoing changes are the modifications you made to your working copy as a result of editing, removing or adding resources. One of the most common requirements in project development is to see what changes have been made to the files from your working copy or to the files from the repository. You can examine these changes after a synchronize operation with the repository, by using the Open in compare editor action.
Other features include a SVN Properties view that allows you to change all the standard SVN properties and also to define your own properties, support for multiple communication protocols like SSL and HTTP/HTTPS, a visual diff/merge tool for comparing images.
For the complete list of features please visit
http://www.syncrosvnclient.com
Pricing and Availability
Syncro SVN Client with One Year Maintenance Pack costs $59
Syncro SVN Client Site License with One Year Maintenance Pack costs $2970
Volume discount rates are available starting with 5 licenses.
Syncro SVN Client can be run on Windows, Mac OS X, Linux, Solaris.
To purchase please visit the Syncro SVN Client store at
http://www.syncrosvnclient.com/buy.html
Syncro SVN Client 2.0 can be freely evaluated for 30 days from
http://www.syncrosvnclient.com/download.html
About Syncro Soft LTD
Syncro Soft is a privately held software company founded in 1998 with a large area of experise in XML technologies: XML Schema, Relax NG, Schematron, XSLT, XPath and XQuery. The main product oXygen XML Editor provides the best coverage of the today XML technologies; it complies with the established standards released by W3C and other organizations and enhances developer productivity through an intuitive and innovative XML IDE. Syncro Soft is a member of the W3C.
oXygen is a registered trademark of Syncro Soft in the U.S and other countries. Subversion is a trademark of CollabNet. Any other trademarks or service marks contained herein are the property of their respective owners.
SOURCE: Syncro Soft Ltd.
support@syncrosvnclient.com
syncrosoft
Return to Announcements
