newbie cant scan - now i can
Postby inva » Tue Jun 14, 2005 9:00 pm
I'm complete novice with Linux! Just loaded Suse 9.3 but i cant seem to get my scanner to work. Canon N650U. When i run Kooka and select preview nothing happens. Any help please (dont be too technical)
Plugged the USB cable direct into the PC instead of the hub !!!!
thanks to those who offered help now i have to try and connect my camera.
inva
RE: newbie cant scan
Postby Rhakios » Tue Jun 14, 2005 9:51 pm
Have you tried to configure it in YaST first?
Postby Guest » Wed Jun 15, 2005 7:37 am
Thanks Rhakios
Have done that but I will try again maybe I haven't done it correctly.My m/c is at home and I'm in work, I'll try this PM.
Postby linuxgirlie » Wed Jun 15, 2005 9:19 am
I would use SANE, its really really good, you need to install the backends and the frontends, it found my canon straight away and is really simple to use.
linuxgirlie
Postby Rhakios » Wed Jun 15, 2005 6:36 pm
Indeed, it should work with SANE as they show complete support
http://www.sane-project.org/sane-mfgs.html#Z-CANON
YaST should have installed the necessary sane libraries, if they weren't already, it can't do any harm to check, then install the xsane front-end and try it with that before giving Kooka a go.
The only problem I occasionally have with my Agfa scanner is that if I let it go to sleep, nothing will wake it, so I just have to switch it off (I use multi-socketed extension leads with individual switches on each socket, so I have no fear of switching everything off), wait a few seconds then switch it on again.
