PHP extracting text from between two seperate points
Postby Diagmato » Tue Dec 05, 2006 10:32 pm
Im trying to write code which:
-finds the first occurance of ... ("..." is a sentance).
-Somehow takes the sentance from between the bbcode, and stores it in another variable
I was initially thinking of explode(), however the start and ending 'tokens' are different.
Any ideas?
My Blog
Micro$oft gives you Windows, Linux gives you the full house
Diagmato
RE: PHP extracting text from between two seperate points
Postby nelz » Tue Dec 05, 2006 11:41 pm
It sounds like a job for a regular expression.
Postby TonyLB » Wed Dec 13, 2006 10:59 pm
If you can identify the end point as well, then use substr(string, start, length)
Find the start position s, the end position e
newString = substr(oldString, s+1, e-s)
Tony
TonyLB
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 2 guests
