Linux Web Woes!
Linux Web Woes!
Postby rossc0 » Thu Jun 09, 2005 8:39 am
Hello!
Got a puzzler - I have Suse 9.2 installed on my box at home. I'm having problems with browsing the web.
konqueror works fine and I have no problems surfing with it.
However I installed Firefox and Mozilla - neither will surf the web - they always timeout on a page. The network settings are the same as Konqueror - but it doesn't load any pages.
I don't know if this is a red herring or not but when I change the network settings from Direct Connection (as it is in Konqueror) to auto-detect from the proxy I can browse web pages - but only those that I have loaded first in Konqueror! (sometimes I have to close and reopen firefox to view them). However, I have problems submitting forms or accessing links from the page and it times out again...
I'm utterly bemused! Any ideas how to get firefox up and running?? I need it so I can ditch my windows partion and do all my dev work in linux! :D
rossc0
Postby 1slipperyfish » Thu Jun 09, 2005 9:41 am
i know this is of little consolation but i am having exactly the same problem in mandriva usually mozilla is so reliable,you just point and go :?
perhaps it is the number of firefox that we are both using(common bug?)
paul
1slipperyfish
Forum Jester
Postby youlikeicecream » Thu Jun 09, 2005 10:53 am
which version ? I installed FF 1.0.4 under Kubuntu (KDE3.4) and all is well
youlikeicecream
Postby rossc0 » Fri Jun 10, 2005 10:19 am
Hmm.. will check and install FF1.0.4 - because Mandriva LE had the same problem...
Will get back asap
rossc0
Postby youlikeicecream » Fri Jun 10, 2005 12:04 pm
I did not get any probs with the version of FF on Mandriva (1.0.1) but I installed the new patched version 1.0.4 anyway.
youlikeicecream
Postby crussell » Fri Jun 10, 2005 3:59 pm
I had the same problem - this sorted it out ...
open /etc/modprobe.conf for editing and add the following lines (you might not need the second one..):
alias net-pf-10 off
alias ipv6 off
crussell
Postby rossc0 » Wed Jun 15, 2005 7:09 pm
Crussell - you are a star!
I put alias net-pf-10 off in my /etc/modprobe.conf.local
rossc0
Postby Guest » Fri Jun 17, 2005 8:42 am
i put both lines into /etc/modprobe.conf and i am now in zilla as i type :D
thanks a million
i think you should get some kind of award :D
paul
Postby 1slipperyfish » Fri Jun 17, 2005 8:44 am
sorry that was me :roll: i forgot to log in again :roll: perhaps i should get some kind of award :wink:
paul
1slipperyfish
Forum Jester
Postby towy71 » Fri Jun 17, 2005 9:10 am
1slipperyfish wrote:sorry that was me :roll: i forgot to log in again :roll: perhaps i should get some kind of award :wink:
paul
perhaps the order of the boot or maybe someone should crown you :lol:
