Linux on Gizmondo
Linux on Gizmondo
Postby tmb_steve » Sat Jun 04, 2005 10:16 pm
Does anyone know if it's possible to put Linux on a Gizmondo? They usually run Windows CE.
Or failing that, does anyone know a way to get SUSE 9.2 to detect and communicate with the Giz via USB? The software that comes with it is Microsoft's Active Sync, which when installed on XP allows you to browse the contents of the device (it comes up as a moblie device).
Any help or insights would be appreciated, thanks!
tmb_steve
Postby bluemonkey321 » Mon Oct 03, 2005 9:36 pm
it is possible and i here that there may be some development
with your usb what do you use kde or gnome
bluemonkey321
Postby tmb_steve » Tue Oct 04, 2005 9:32 am
I use KDE 3.4 on SUSE 9.3 (i upgraded since I posted)
But I can easily set up a computer with Ubuntu or something if gnome is better for this.
tmb_steve
