IDE for C++
Goto page 1, 2  Next
minich
PostPosted: Wed Oct 18, 2006 7:06 am    Post subject: IDE for C++ Reply with quote
Hi all,
I want to find out an answer for the following question:
which IDE is the best for C++ coding in Linux?
I tried to use xEmacs, nedit but I want to find IDE which will combine powerfull possibilites for editing and ease for using
GMorgan
PostPosted: Wed Oct 18, 2006 7:39 pm    Post subject: RE: IDE for C++ Reply with quote
Depends on what GUI toolkit you want to use (if any). Kdevelop has decent integration for QT's RAD tools and I think Ajunta has decent integration for GTK. So really its a case of horses for courses. Code completion is quite good with Kdevelop and it uses KATE as its editor (it used to have an embedded VIM element as an alternative but they had removed it last time I checked).
1slipperyfish
Forum Jester
PostPosted: Wed Oct 18, 2006 8:53 pm    Post subject: Reply with quote
how about dev-c++??
here
i have only used it in m$ though Embarassed
paul
xxxPeNgUiNxxx
PostPosted: Tue Oct 24, 2006 4:31 pm    Post subject: Reply with quote
I just want to say that I like your signature 1slipperyfish (troll)
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Tue Oct 24, 2006 4:53 pm    Post subject: Reply with quote
for gawd's sake don't encourage him Rolling Eyes Rolling Eyes Rolling Eyes
1slipperyfish
Forum Jester
PostPosted: Tue Oct 24, 2006 8:19 pm    Post subject: Reply with quote
thankyou you're very kind Very Happy
paul
PostPosted: Tue Oct 24, 2006 8:23 pm    Post subject: Reply with quote
see he gets slimier as you get to know him Twisted Evil Evil or Very Mad Twisted Evil
xxxPeNgUiNxxx
PostPosted: Tue Oct 24, 2006 9:24 pm    Post subject: Reply with quote
Well, it is a good idea, I've seen signatures like these but none of them made sence neither did this but I like them Smile
Just kidding, I don't know perl but I could get what it does Smile that's all Smile
PostPosted: Tue Oct 24, 2006 10:21 pm    Post subject: Reply with quote
He's been picked up on his crappy programming skills and atrocious spelling, we try to ignore him Wink
xxxPeNgUiNxxx
PostPosted: Wed Oct 25, 2006 7:41 am    Post subject: Reply with quote
I can see that, he doesn't use CAPITAL LETTERS, he wrote "thankyou" instead of "thank you" but he is kind of uselul :-/ (I think)
PostPosted: Wed Oct 25, 2006 11:40 am    Post subject: Reply with quote
Howdy,
Aside from the mentions above, the one i use ... of course (wink).
Some Thoughts:
I recently stumbled on 'eclipse' which appears to be designed to provide a front end for what ever tools a person might chose to plug into it.
I can't quite tell at the moment as the documentation fonts are about the size of tiny little black ants and the xml that renders them has no config options available from the gui.
But, looking through my magnifying glass they seem quite extensive and to the point. I could just make out mentions of both c++ and java.
I just recently repacked the package(s) from a very buggy knoppix 5.0.1 LiveCD and haven't had a chance to look at it properly, or visit the site. So i hope i'm not to wrong in my impression so far.
But an my initial look was quite promising, every thing else appeared configurable, including the scheme fonts ... menus/editors etc. Just the help/doc facility seemed locked out.
As it was a binary, the flexibility of the gui configuration impressed me. And as the gui documentation/help system, being extensive, is likely a set of xml files, i figure it would just be a matter of looking for where therev'e got them screwed down and doing an edit.
If it is what i seem to think it is at the moment, i can see my self using that package.
On Another Tack:
For a nice smooth designer, The Full Tick (FLTK) might be worth a look.
www.fltk.org
As smooth as cbuilders' designer. Needs to work with other tools though, editors/compiler etc, as it's just a designer, not an integrated environment. It's configured in a novel way too. Graphically via a set of 'projects' in the 'fluid' directory that hangs off the top level src directory.
http://counter.li.org
shifty_ben
PostPosted: Wed Oct 25, 2006 7:37 pm    Post subject: Reply with quote
I have to say I never thought I would see the day when 1sf (troll) was referred to as useful, even in passing!
In answer to your question I can recommend Kdevelop as I used to use it, now I seem to have started using the Kate text editor for everything, not sure when the change came around but there ya go!
Need a New Signature
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Wed Oct 25, 2006 11:05 pm    Post subject: Reply with quote
Well, he got you to bite (grin), did he not (grin),
Howdy shifty ....
shifty_ben
PostPosted: Wed Oct 25, 2006 11:10 pm    Post subject: Reply with quote
Yup, I guess he did Wink
Hows it going JJ?
minich
PostPosted: Thu Oct 26, 2006 8:31 pm    Post subject: Reply with quote
Hi all,
Thanks for your answers. The thing is that I'm going remove windows from my computer at all (clapping;) and i wanna find all programs I need to have. At the moment i'm using nedit, but it's not enough for rather big projects. Maybe kDevelop will be my choice
Goto page 1, 2  Next
Page 1 of 2
