External USB HDD
External USB HDD
Postby youlikeicecream » Fri Jun 03, 2005 11:58 am
HI, I am having a small problem. I am using a USB2 160GB LACIE External HDD, formatted as a primary FAT32 partition ... Whenever the Disk is connected, an Unmounted icon is placed on the desktop ... I can click on it and it mounts just fine. Unfortunately I cannot write to it. Checked the permissions and I should be able to write to it but it still denies me write access. Ideally I would like to just put the entry for this disk into my /etc/fstab file. And I have done so with a command as such :
/dev/sdb1 /mnt/LACIE vfat 0 0 (I think thats what I put) I have even tried it with fmask=775,dmask=775
but it still wont let me write. Also when I have mounted sdb1 to /mnt/LACIE the automated USB icon gets confused because it wants to mount the device sdb1 to /media/sdb1.
I am using Kubuntu (latest) with KDE 3.4
any help would be most appreciated
Mike Smith :)
youlikeicecream
RE: External USB HDD
Postby youlikeicecream » Fri Jun 03, 2005 3:01 pm
Can anyone help ?
youlikeicecream
Postby towy71 » Fri Jun 03, 2005 3:42 pm
my advice would be to let udev create the icon and then as root in a terminal type: umount /media/sdb1
then type mount -rw /media/sdb1
not pretty but I think it would work
ymmv
Dick
Postby youlikeicecream » Fri Jun 03, 2005 5:28 pm
thanks for the advice, but that would leave my user unable to write to the drive I would have thought? What I really wanted was for the drive to be mounted at boot as udev doesn't mount it at boot, you actually have to click on the icon to mount it. I wanted to store icons and piccies on the USB disk, and so it would be nice for it to mount at boot so that my icons and backgrounds are available when i log in.
Mike :)
youlikeicecream
Postby towy71 » Fri Jun 03, 2005 10:53 pm
doh! There was I shooting my mouth off again, the /etc/fstab section should read:
/dev/hda1 /mnt/lacie vfat defaults 0 0
HTH
Dick
Postby skecs » Sat Jun 04, 2005 7:27 am
towy71 -
"doh! There was I shooting my mouth off again, the /etc/fstab section should read:
/dev/hda1 /mnt/lacie vfat defaults 0 0"
Don't you mean:
/dev/sda1 /mnt/lacie vfat defaults 0 0 :?
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
Postby towy71 » Sat Jun 04, 2005 7:30 am
double doh ;)
nice sig skecs
Postby skecs » Sat Jun 04, 2005 7:56 am
Ta - it's how I learnt to draw on computers!
There is a whole site of ASCII penguins at ASCII-Pinguine:
http://www.informatik.uni-freiburg.de/~ ... nguin.html
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
Postby wyliecoyoteuk » Sat Jun 04, 2005 8:33 am
The best solution would be to write a script for udevd.
this link might help.
http://www.linuxformat.co.uk/index.php? ... topic&t=61
Postby youlikeicecream » Sat Jun 04, 2005 9:12 am
is what I have tried before, i will see if that works this time and then if not will try ther udev thing
thanks
mike :)
youlikeicecream
Postby youlikeicecream » Sat Jun 04, 2005 9:21 am
ok, i tried that ... didn't mount at boot and as root i tried this ...
root@Kubuntu:/home/mike # mount /mnt/LACIE
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
youlikeicecream
Postby youlikeicecream » Sat Jun 04, 2005 9:23 am
PS . it is sdb1, my ntfs SATA disk is sda1
mike :)
youlikeicecream
Postby youlikeicecream » Sat Jun 04, 2005 9:27 am
root@Kubuntu:/home/mike # mount -t vfat -rw /dev/sdb1 /mnt/LACIE
>>couldnt write to it as root.
root@Kubuntu:/home/mike # chmod 775 /mnt/LACIE
>>still couldnt write
am confused
youlikeicecream
Postby Nigel » Sat Jun 04, 2005 9:36 am
shouldn't that be
mount -t vfat -o rw /dev/sdb1 /mnt/LACIE
at least, that's what is implied by the man page for mount under SuSE 9.2
Postby youlikeicecream » Sat Jun 04, 2005 9:41 am
yeah, thats it. But it allows only root to write to it. what do i need to do to get access for my user (also part of the 'root' group)
youlikeicecream
