Tedious rendering
Tedious rendering
Postby donoreo » Tue Sep 19, 2006 3:00 pm
I was going to mention it before, but finally it has annoyed me too much. This site renders horribly in FF (Windows, Linux, and Mac). The left column is fast, the centre is so-so but the right column is freaking annoying. It is so slow to actually render, and then the middle column adjusts size when it does.
Honestly, I have not tried in any other browser.
Anything that can be done about this?
I cannot deny anything that I did not say.
donoreo
RE: Tedious rendering
Postby M-Saunders » Tue Sep 19, 2006 3:38 pm
It all looks fine in FF here (Linux and Windows). I can't see that there's anything in the right-hand pane that would cause a slowdown -- the advert image is stored on the LXF server, along with the rest of the site.
What's the spec of your PC, and what type of connection do you have?
Anyone else having similar problems?
Mike
M-Saunders
Re: Tedious rendering
Postby nelz » Tue Sep 19, 2006 4:00 pm
donoreo wrote:Anything that can be done about this?
Use the ExtraLite theme, it's much faster. Click on My Account in the left hand menu and go to the theme section.
RE: Re: Tedious rendering
Postby Diagmato » Tue Sep 19, 2006 6:02 pm
I used to have rediculous problems whilst in USA, on dial-up, but here it seems to be fine (broadband).
If the right hand images havent been cached (first visit to page), then the right hand does take a noticable time to finish.
[edit]
This seems to vary - sometimes it comes up the moment the centre section does, other times it takes roughly 3 seconds longer to show up.
My Blog
Micro$oft gives you Windows, Linux gives you the full house
Diagmato
Postby donoreo » Tue Sep 19, 2006 7:34 pm
It is the same on ANY of my machines (T43 Thinkpad, AMD 3300, G4 1Ghz Mac). I will try the different theme.
donoreo
Postby kilikopele » Wed Sep 20, 2006 12:00 am
That's a great tip. I didn't even think I was rendering slow, but I'm now rendering more quickly. Thanks!
(I'm also not getting the Windows IE "problem" icon in the lower left.)
kilikopele
Postby donoreo » Wed Sep 20, 2006 1:22 pm
This lighter theme is faster. The biggest speed increase is because there is no right hand column :)
donoreo
Return to This Website
