HD DVD player, and DVI.
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic
Xraynorm
PostPosted: Sun Sep 17, 2006 10:54 am    Post subject: HD DVD player, and DVI. Reply with quote
Hello.
Does anyone know if its possible to connect a HD DVD player (with HDMI) to a computer monitor with a DVI input.
You can buy HDMI to DVI adaptors(i think), but will it work?
C64, Amiga 500, Amiga 600, Amiga 1200 + 030, AMD K62-500, Sempron 2200, P3 Laptop, P4 Laptop, Acer One Netbook (Linux).
PostPosted: Sun Sep 17, 2006 12:03 pm    Post subject: RE: HD DVD player, and DVI. Reply with quote
There are plenty listed with retailers - you need to check if these are HDMI "compatible". That is - will the signal stay HD or will these cause the signal to be downgraded to "standard definition"?
The only way to do this would be contacting manufacturers directly or face-to-face (with a demonstration) in-store.
Xraynorm
PostPosted: Tue Sep 19, 2006 6:39 pm    Post subject: RE: HD DVD player, and DVI. Reply with quote
Thanks.
Quote:
You need to check if these are HDMI "compatible"
Do you mean the monitor, DVD player, or cable?
PostPosted: Wed Sep 20, 2006 11:09 am    Post subject: Re: RE: HD DVD player, and DVI. Reply with quote
Xraynorm wrote:
Thanks.
My understanding is all of them - if one component isn't compatible the picture will be downgraded. More details at:
High-Definition Multimedia Interface
High-Bandwidth Digital Content Protection
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic All times are GMT
