Linux DVD RAM : Help needed
Postby twitcher » Wed Jun 01, 2005 12:17 pm
I'm a relative nooob to the wonderful world of Linux. I've got an LG super multi DVD drive and want to write to DVD RAM. I'm using Suse 9.0 on an AMD Sempron based machine. I can write to CD-R and DVD-R, but not DVD RAM ,the drive can read content on the DVD RAM disks but cannot write to the disk. I'm under the impression that Suse 9.0 should be able to read and write to DVD RAM ? any ideas where I'm going wrong? Thanks in advance
twitcher
RE: Linux DVD RAM : Help needed
Postby Nigel » Wed Jun 01, 2005 1:10 pm
How are you trying to write to it ?
I was under the impression that DVD-RAM was like CD-RW, ie a rewriteable DVD. You should be able to write to it, and erase it, using k3b or whatever your favourite burning app is. What you won't be able to do is treat it like another hard drive (ie mount it in read/write mode).
Linux DVD RAM
Postby twitcher » Wed Jun 01, 2005 1:26 pm
Hi Nigel,
I was hoping that I could use DVD RAM in a drap n drop format exactly like a hard disk moving files to and fro using the OS. No burning app required. It's the only reason that I have Windoze on my machine, beacuse of this functionality. I must admit I've not tried to use K3b with a DVDRAM, I will give it a try. So is there no way to mount a DVDRAM in read write mode, even if I upgrade to the latest release of SUSE (or other distro if I must!)
twitcher
RE: Linux DVD RAM
Postby nelz » Wed Jun 01, 2005 2:00 pm
You should be able to use dvd-ram like that. Try searching Google, there are a few sites with some information on this.
RE: Linux DVD RAM
Postby Guest » Wed Jun 01, 2005 4:21 pm
Nigel hasn't got a clue...
...but at least he is not a coward without a clue, like me.
Re: RE: Linux DVD RAM
Postby Nigel » Wed Jun 01, 2005 5:15 pm
Anonymous wrote:Nigel hasn't got a clue...
Probably true, but uncalled for. I've probably got more years experience in the computer industry than you've had hot dinners, which has taught me that I don't know everything. Which is why I qualified my comments with "I was under the impression that...", which I was at the time.
At least I try to help, instead of posting snide anonymous comments...
RE: Re: RE: Linux DVD RAM
Postby twitcher » Thu Jun 02, 2005 10:12 am
Nigel,
Thanks for trying to help, sorry that you got flack from the anon user.
twitcher
Postby towy71 » Thu Jun 02, 2005 11:22 am
IMHO anonymity is last refuge of a scoundrel !
Postby Nigel » Thu Jun 02, 2005 11:31 am
Thanks, folks... I know I shouldn't rise to idiots like that, but it just put the icing on the cake of a bad day yesterday (fgetpos, fseek, MS compilers - don't ask :evil: )
That plus the return of the chinese graffiti & the idiot with the texas poker links just strengthens my opinion that anonymous posting should be disallowed.
Postby towy71 » Thu Jun 02, 2005 12:51 pm
Makes one wish that you could direct the Monty Python foot to crush these f***wits :evil: :twisted: :twisted: :twisted:
Re: Linux DVD RAM
Postby Guest » Thu Jun 02, 2005 1:43 pm
twitcher wrote:No burning app required. It's the only reason that I have Windoze on my machine, beacuse of this functionality.
Windows doesn't have this functionality either.
Granted, Windows XP has a basic burning app built in, but it works like any other burning app... i.e. select a file to burn or drag a file onto the app's window, select the 'write' or 'burn' button a wait until finished.. There is no real-time r-w app available on Windows or Linux.
RE: Re: Linux DVD RAM
Postby Guest » Thu Jun 02, 2005 3:18 pm
Guest, you are right of course.
I was a bit lazy in my post, the DVDRAM drag n drop functionality is created by software provided with the DVD burner. This allows files to be moved to the DVDRAM by the GUI without using a burning app front end. My LG burner had Nero bundled, my Toshiba SD-W1011 had software from Vob.de bundled with it. The software runs in the background on my Win98 HD and I had forgotten all about it. It got me thinking though and I've just discovered NeroLinux http://www.nero.com/eng/NeroLINUX.html
which I shall investigate!
cheers to all :D
Postby twitcher » Thu Jun 02, 2005 3:36 pm
Sorry, forgot to log in, the above post was by me
twitcher
Postby Guest » Thu Jun 02, 2005 5:11 pm
NeroLINUX works but it's not on par with K3b and looks ugly too.
K3b is the premier burning app for Linux
Postby MC » Fri Jun 03, 2005 12:20 pm
Hi twitcher,
To use a DVD-RAM disc under Linux you must be using a 2.6 kernal.
Insert DVD-RAM into drive then type in a shell
mount /dev/cdrom1 /mnt (substitute cdrom1 for your drive id)
You must then format the disc for use by typing
mke2fs /dev/cdrom1
Files can then be dragged to\from disc.
Disc is unmounted with
umount /mnt
I have the LG super multidrive, help the above is helpful.
MC
MC
