SOLVED: 89 key "shorty/laptop" style keyboard &
Postby alloydog » Wed Jun 01, 2005 5:08 am
I'm using Slackware 10.1 with Xorg with a small "shorty/laptop" style keyboard which has 89 keys - no numberpad to the right.
Most of the keys work, except the alternative characters, such as @ and £ and so on - that is, <Alt Gr>+<key>. even <Ctrl>+<Alt>+<key> doesn't work.
With xorg.conf (and xf86config) the smallest keyboard seems to be 101 keys.
Any ideas?
alloydog
RE: 89 key "shorty/laptop" style keyboard & X/
Postby dandnsmith » Wed Jun 01, 2005 8:32 am
Have a look at man pages for keymaps and xmodmap - I think it may be the stuff you want.
The @ and £ sound like a country/language problem - the UK and US keyboards are different in layout for these.
Derek
dandnsmith
Postby alloydog » Wed Jun 01, 2005 10:37 am
Thanks, I will do - I did look for the man pages, but wasn't sure which ones.
I am using a Finnish/Swedish keyboard, for which a normal sized keyboard is a 105 key keyboard ("4" in xorgconf setup) and fi/latin1 as the map.
alloydog
Postby alloydog » Wed Jun 01, 2005 7:42 pm
I just replaced "101" with "105" in the keyboard section of XF86Conf & it now works.
alloydog
