Toshiba SD-R6112 DVD drive will not open
Postby md41 » Wed Aug 09, 2006 3:36 pm
Hey,
I have just changed over to Linux. I'm using openSUSE 10.1. I have a problem with my Toshiba DVD drive however. Its has been recognised and properly installed by SUSE yet it wont eject while the OS is running. It does read CDs and DVDs correctly, it just won't eject!
Anyone know why?
Here is the error message I recieved:
umount: it seems /dev/hdc is mounted multiple times
eject: unmount of `/dev/hdc' failed
Thanks in Advance
md41
RE: Toshiba SD-R6112 DVD drive will not open
Postby nelz » Wed Aug 09, 2006 3:42 pm
Can you post the contents of /etc/fstab and /etc/mtab?
Postby md41 » Wed Aug 09, 2006 4:35 pm
Below is fstab:
/dev/hda2 / reiserfs acl,user_xattr 1 1
/dev/sda1 /windows/D vfat users,gid=users,umask=0002,utf8=true 0 0
/dev/hda1 swap swap defaults 0 0
proc /proc proc defaults 0 0
sysfs /sys sysfs noauto 0 0
usbfs /proc/bus/usb usbfs noauto 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
/dev/dvdrecorder /media/dvdrecorder subfs noauto,fs=cdfss,ro,procuid,nosuid,nodev,exec,iocharset=utf8 0 0
Below is mtab:
/dev/hda2 / reiserfs rw,acl,user_xattr 0 0
proc /proc proc rw 0 0
sysfs /sys sysfs rw 0 0
udev /dev tmpfs rw 0 0
devpts /dev/pts devpts rw,mode=0620,gid=5 0 0
/dev/hdc /media/dvdrecorder subfs ro,nosuid,nodev,fs=cdfss,procuid,iocharset=utf8 0 0
/dev/hdc /media/disk-1 iso9660 ro,nosuid,nodev 0 0
md41
Postby nelz » Wed Aug 09, 2006 5:08 pm
It is indeed mounted twice, once on /media/dvdrecorder and once on /media/disk-1. Both need be unmounted before you can eject the disc.
The entry in /etc/fstab would appear to be causing the problem (I have no such entry on my SUSE 10.1 setup and it automounts CDs fine), so comment it out by placing a # at the start of the line. You'll need to be root to edit the file, the easiest way to do this is is to open a root shell with "Applications -> System -> Terminal -> Terminal Program - Super User Mode" and type "gedit /etc/fstab".
Postby md41 » Wed Aug 09, 2006 6:29 pm
hey, ok I ran terminal for "gedit /etc/fstab" and fstab file comes up but what do I do to unmount?
md41
Postby md41 » Wed Aug 09, 2006 6:33 pm
md41
Re: RE: Toshiba SD-R6112 DVD drive will not open
Postby wyliecoyoteuk » Wed Aug 09, 2006 6:50 pm
nelz wrote:.comment it out by placing a # at the start of the line.
then save it.:D
then reboot, probably, is easiest. this will stop it being mounted twice.
Postby nelz » Wed Aug 09, 2006 8:27 pm
md41 wrote:hey, ok I ran terminal for "gedit /etc/fstab" and fstab file comes up but what do I do to unmount?
umount /media/dvdrecorder
RE: Re: RE: Toshiba SD-R6112 DVD drive will not open
Postby md41 » Thu Aug 10, 2006 11:34 am
Thank you, that seems to have sorted it!
md41
