Best Linux Internal Modem
bibstha
PostPosted: Sun May 29, 2005 10:39 am    Post subject: Best Linux Internal Modem Reply with quote
I have this motorola modem
which although i tried its driver fromthe website couldn't get running
so,i was thinking of buying a new internal modem,
any suggestions?? which internal modem works good on
RED HAT.
i have red hat 9 installed in my pc
PostPosted: Mon May 30, 2005 11:50 am    Post subject: RE: Best Linux Internal Modem Reply with quote
www.linmodems.org should give you a pointer as to which internal modems might work. Best approach, however, is to use an external serial(RS-232) modem. You should be able to pick up a second-hand one for £10 or a new one for about £20-£40.
Regards,
Zeno
dandnsmith
PostPosted: Tue May 31, 2005 7:59 am    Post subject: RE: Best Linux Internal Modem Reply with quote
I'd support the external modem choice for RH9 - later releases of linux stuff may well be better, but internal modems which are likely to be 'winmodems' can give a lot of trouble.
Derek
Nobber
PostPosted: Tue May 31, 2005 2:48 pm    Post subject: RE: Best Linux Internal Modem Reply with quote
Real internal (PCI) modems that need no special driver can be found if you look hard enough, though they tend to be much more expensive than softmodems. For years I used one made by Multitech. It cost about £100, but worked a treat.
