CSS: Floating a nested div.
Postby Spitfire » Tue Aug 08, 2006 8:14 pm
I'm having a problem with some css. In order to get the menu to be on the left I set the float to left. However, this then produces a problem when the rest of the page content isn't enough to cover the height of the menu...
It's probably easier to understand by looking: http://www.arrowesecuritysystems.co.uk/new/
When the window is fairly narrow all is well and good, once the window is widened the menu juts out at the bottom.
I would appreciate any insight you may have into this.
Regards,
Matt
Spitfire
RE: CSS: Floating a nested div.
Postby Gordon » Tue Aug 08, 2006 9:44 pm
I've not tried floating a nested div in CSS. My method is to use absolute positioning for div's. See http://www.gordonmurgatroyd.pwp.blueyonder.co.uk/ for how I create menus. Also try looking at Eric Meyer's website and look at his CSS/Edge pages. You may be able to find info there.
Hope this helps.
Gordon
Postby Spitfire » Tue Aug 08, 2006 10:21 pm
The problem with absolute positioning, as well as this float method, is that the outer div - the one that produces the border effect - does not expand to surround the positioned items.
Thank you for the links though, some interesting ideas.
Regards,
Matt
Spitfire
Postby emyr42 » Wed Aug 09, 2006 3:04 pm
Bah, browser rendering bug...
have you set a minimum height for the container div?
OpenSUSE 10.2, WinXPHome
AMD Sempron 2400, 512MB DDR333, Twin 60GB Deathstars
emyr42
Postby ollie » Wed Aug 16, 2006 9:31 am
Just a real quick look - I think you need a container around #sidebar and #content with a "clear: left" on the #content div.
A better place to ask this would be the Web Standards Group mailing list (also free) - you can also search the archives for solutions.
Sorry, I just haven't got time to troubleshoot your CSS - but using the View Source Chart Firefox extension makes this easier.
Postby Spitfire » Wed Aug 16, 2006 7:02 pm
Thanks for your reply. I ran with that and ended up using the #content:after to have a clear: left; which I found on http://www.positioniseverything.net/easyclearing.html, to clear up the xhtml. It now looks as I intended... On firefox, I've yet to try it on IE.
Regards,
Matt
Spitfire
