data array??
data array??
Postby alloydog » Thu Jul 27, 2006 4:17 pm
I'm not a 100% sure if I'm on the right track...
I am going to try and right a programme (for a wargame) that calculates the damage done by a weapon. The weapon has several 'characterisitics', being:
• name
• one- or two-handed
• number of dice to roll (if one-handed)
• number of dice to roll (if two-handed)
• bonus points (if one-handed)
• bonus points (if two-handed)
Some weapons can be used only two-handed, or only single-handed. for example:
                ONE-HANDED    TWO-HANDED
TYPE           DICE   BONUS  DICE   BONUS
Broadsword      -       -     5       2
Bastardsword    3       2     4       0
Sword           3       0     -       -
How would I put this information so that a C++ programme could use it?
The aim is for the used just to select the weapon used and the programme returns a value for the damage done.
Is data array the correct term?
alloydog
RE: data array??
Postby GMorgan » Thu Jul 27, 2006 4:36 pm
Personally I'd create a struct to account for the weapon. Prehaps something like this.
typedef struct{
string name;
int numhands;
int weapontype;
int basedamage;
}weapon;
Here name is obvious, numhands is the handedness of the weapon so obviously 1 and 2 are the correct values. The value weapontype would contain an index for the weapon. So sword may enter 1, mace 2, bow 3 etc. Variable basedamage would give you your lowest damage value.
Just add fields for all the other posibilities then create an array of them. So your array might be created like this.
weapon allweapons[x];
Where x is the number of entries. To access the different fields you use the following.
allweapons[x].numhands = y;
or
y = allweapons[x].numhands;
When called like that all the normal operations work on them as they would for the normal datatypes including assignments as LV's and RV's as above or for use in comparisons.
//edit - a quick tip about arrays. They are indexed from 0 so 0 is the first entry not 1.//
GMorgan
RE: data array??
Postby alloydog » Fri Jul 28, 2006 7:08 am
Thanks, that's given me somewhere to start from!
alloydog
RE: data array??
Postby GMorgan » Fri Jul 28, 2006 8:05 pm
Another thing, remember to place the struct definition in the files header rather than inside a function.
GMorgan
