Anjuta 1.2.4a problem on SUSE 10.1
Postby Groucho » Mon Jul 24, 2006 7:39 pm
Using Anjuta 1.2.4a on a newly installed openSUSE 10.1 system (fully updated).
I modified Anjuta's basic "Hello World" terminal program to see if I could examine local vars and set watches. Call stack and breakpoints seem to work, but local variables don't.
Is this a known bug? Is there a better C++ IDE available that I could be using? Some update I'm missing?
Thnx.
Groucho
RE: Anjuta 1.2.4a problem on SUSE 10.1
Postby bluemonki » Wed Jul 26, 2006 1:27 pm
You can try Eclipse (http://www.eclipse.org), natively it's a Java IDE but it's more of a framework so you can get the CDT plugin (http://www.eclipse.org/cdt/) and use it for C++.
The GUI integrates with GDB so debugging is easy :)
A wizard has turned you in to a whale. Is this awesome? (Y/N)
bluemonki
