MachuMan
Joined: Tue May 24, 2005 10:55 pm Posts: 67 Location: London UK
Posted: Tue May 24, 2005 11:05 pm Post subject: Can you uninstall Xen? is it worth installing? |
Hello, Am new to this so bare with me.
I have been fooling around with linux for over a year now and i have for the past few months had the pleasure of Mandrake 10.1 (gnome) running sweet as a nut. However Xen has caught my eye as i always enjoy checking out new distros.
Basically i want to know that i wont mess up my current set up by installing xen, and know that i can ditch it if i change my mind (which i often do).
Any thought at all? |
jjmac LXF regular
Posted: Fri May 27, 2005 1:16 pm Post subject: RE: Can you uninstall Xen? is it worth installing? |
About the only messing up it could do would be if you allowed it to install a boot loader to your mbr. As you have a Linux in already, i'd expect there is a Grub or Lilo already set up.
So, just formate a new partition for the install, and install it there. Make a boot disk for your existing installation first. When the new install wants to know if you want it to install a boot loader to your mbr ... tell it __no__.
Then, reboot into your first install and add a reference to the new install in your existing Linux boot loader config, as used by the original Linux install.
If you let it install a loader to your mbr, you will just have to configure it to see your other Linux, and whatever else you may have there. So, it's hardly worth it, as it is already set up.
Getting rid of it ... just ignore it, or remove the partition from the table list. Or over-write it.
A lot of people forget to restore the saved copy of their mbr, that the Linux loader would have made, when they do a final Linux uninstall. That is, they delete all of there Linux from the partition table list.
Basically, Lilo or whatever will still be there, and because it still needs the table entry to find its' second stage ... and the table entry has been removed, the whole thing just hangs.
In lilo you would be looking for a file called /boot/boot.0300 more than likely. No idea what Grub calls it. Also, in lilo you would do ...
]# lilo -u
to restore that file before uninstalling Linux. And even then, it's only required for the Linux that is providing the Loader service.
I haven't a clue as to how Xen performs is as an OS though.
| Code: |
-|- If the systems the answer, then the question
must have been really stupid -|-
Nobber LXF regular
Joined: Mon Apr 11, 2005 4:24 pm Posts: 370 Location: Nova Scotia
Posted: Fri May 27, 2005 4:31 pm Post subject: RE: Can you uninstall Xen? is it worth installing? |
Xen's a piece of software, not a distro. The only messing about with the bootloader you will need to do is add/modify an entry for the Xen-enabled kernel of your host distro.
Or am I the one who's lost the plot? _________________ 800 LINES ERIC - GET BACK TO PYSKOOL |
brian
Posted: Fri May 27, 2005 6:27 pm Post subject: |
nope, I don't think you've lost the plot, you have the same understanding as me  |
towy71 Moderator
Posted: Fri May 27, 2005 6:32 pm Post subject: |
you probably lost the plot but you are also right I couldn't find Xen as a distro on www.distrowatch.com which came back with: The distribution you requested does not exist in our database _________________ still looking for that door into summer |
MachuMan
Posted: Fri May 27, 2005 10:02 pm Post subject: |
Dudes sorry i wasnt very clear earlier. I meant i'm new to posting in forums and Xen isnt a distro its a piece of software that allows you to run multiple OS at the same time.
My question is can i uninstall xen without damaging my current mandrake install. As from what i understand it alters the kernal when you install it.
Also is it a good as its made out to be. Basically i want to know that i wont mess up my current set up by installing xen. |
jjmac LXF regular
Posted: Sat May 28, 2005 11:33 am Post subject: |
Well ... i think i might be losing the plot (grin)
So, how does it work ... what is it. ?
My question/answer is still the same
Could you elaborate on how it actually goes about itself. If it installs as a kind of distro, then it should go into its own partition. So ... why would it interfere with anything.
But your saying it's a piece of sw. so ... i can't quite see it at this stage, more info please ...
Is it some sought of emulator, wrapper, or just an eloborate MS styled boot menu program.
The later one there concerns me (grin)
| Code: |
skecs
Joined: Fri Apr 22, 2005 10:22 am Posts: 76 Location: Bathurst, NSW Australia
Rhakios Moderator
Posted: Sat May 28, 2005 4:32 pm Post subject: |
Xen consists of a patched kernel and some utilities.
If you install a Xen enabled kernel alongside your existing kernel then you will not have any problems as you can always go back to booting from your normal kernel if you decide you don't want Xen any more. In this respect Xen is very similar to other emulators which require kernel patches (e.g. the old version of Win4Lin). Of course you can always uninstall the utilities.
It seems to me that one of the main differences with Xen is that it requires a modification of the guest OS as well as the host, as such you can't just install anything you happen to have the install disc for. Xen is rather more of a professional than a hobbyists tool. _________________ Bye, Rhakios |
1slipperyfish Forum Jester
Posted: Tue May 31, 2005 11:16 pm Post subject: |
i'm also new to this type of thing and i found that pclinux livecd install produced the effect when not choosing the bootloader option that i couldn't boot anything(not even my beloved w$ )
paul _________________ i am a follower of the culture
slowandgo
Joined: Thu Apr 07, 2005 1:29 am Posts: 17 Location: San Jose, Ca
Posted: Wed Jun 01, 2005 12:44 am Post subject: |
I just installed SuSe Professional 9.3 and it comes with Xen as an option to install. When I installed it it created a boot option in Grub. I am currently running a dual boot Dell 8300 with XP Pro and SuSe 9.3 with another option to run XEN.
I haven't played with it yet, I am a newbie to Linux so I will be taking my time working with it.
Slow and Go  |
MachuMan
Posted: Wed Jun 01, 2005 1:04 pm Post subject: |
I see, so if i wanted to stop using xen i could just stop booting to it?
One more point, going back to Rhaikos' point.
"It seems to me that one of the main differences with Xen is that it requires a modification of the guest OS as well as the host, as such you can't just install anything you happen to have the install disc for."
When you go about installing another "guest OS" do you have to find a distro with the kernal updated or will xen patch the kernal when you install it? Also when installing other OS would you have to give them there own partitions or can they run more like "programs" in the Xen "host" OS.
Thanks for your replies so far _________________ Whats ' a machu' with you?
Slackware, sexy linux |
Rhakios Moderator
