itx-weather
Joined: Wed Apr 13, 2005 12:09 am Posts: 2 Location: Wales, U.K.
Posted: Sun May 22, 2005 1:09 am Post subject: Connecting to an NSLU2 from the internet. |
Can anyone advise how to go about connecting to a Linksys NSLU2 from the internet. This is by all accounts a feature of an NSLU2 but i've not been successful in finding documentation on this.
Thank you in advance for any suggestions.
Best Regards. |
MOR
Posted: Mon May 30, 2005 11:31 pm Post subject: RE: Connecting to an NSLU2 from the internet. |
| As far as I know this is a feature that would have to be supported by your router / modem that the NSLU2 is connected to. This can be done with port forwarding if supported. You should also be able to connect via a VPN. If you use the unslung config then you can set the NSLU up as a simple webserver. |
