depreciated libraries
Postby alloydog » Fri Jun 23, 2006 11:15 am
I posted this one before, ages ago, but it looks as if it has been cleared out, as the forum posts don't seem to go back that far.
Anyway, When I used Xwpe to compile Helloworld.cpp, I got a wordy warning about the library used, in this case iostream.h being depreciated.
I am using "Teach Yourself C++ in 21 Days", which is a few years old.
So, what libraries should I be using?
alloydog
RE: depreciated libraries
Postby Gordon » Fri Jun 23, 2006 4:04 pm
This warning means that you have used the declaration
#include <iostream.h>
inside your source file but for proper C++ you neead to use
#include <iostream>
For the proper (2nd) method to work correctly you may also need to use the statement
using namespace std;
somewhere near the beginning of your code and also call the compiler with
g++ -o helloworld Helloworld.cpp
Are you using "Teach Yourself C++ in 21 days" or "Teach yourself C++ for linux in 21 days"?
Gordon
Postby alloydog » Fri Jun 23, 2006 7:08 pm
The full warning is:
#ifdef __DEPRECATED
#warning This file includes at least one deprecated or antiquated header. \
Please consider using one of the 32 headers found in section 17.4.1.2 of the
C++ standard.  Examples include substituting the <X> heqader for the >X.h> \
header for C++ includes, or <sstream> instead of the deprecated header \
<strstream.h>  To diasble this warning use -Wno-deprecated.
#endif
I tried using just <iostream>, but I then got a different warning.
I think <iostream> has been replaced with something different.
Using <iostream.h>, the programme still compiled and ran OK.
I am using the "Teach Yourself C++ in 21 days".
alloydog
Postby GMorgan » Sat Jun 24, 2006 1:17 am
iostream is the central input and output header for C++, its crucial to most C++ programs. You could use cstdio or stdio.h* but that is orignal C rather than C++. Your using Ubuntu aren't you, have you tried sudo apt-get install build-essential, it should ensure that your uptodate with the libraries.
*the original C headers used the .h notation. In C++ they dropped the .h. C++ also included original C functions repacked for C++ but with c in front of the original name. Hence stdio.h becomes cstdio, they both perform the same functions. iostream should work though and is the standard way of doing things in C++.
GMorgan
Postby Gordon » Sun Jun 25, 2006 9:12 am
What warning did you get when you used the <iostream> declaration?
Gordon
