pclinux login problem?
1slipperyfish
Forum Jester
PostPosted: Thu May 19, 2005 9:44 pm    Post subject: pclinux login problem? Reply with quote
i have a "friend" who was using pclinux live but didn't install it but forgot to take note of the passwords for root and guest Confused then installed the mandriva distro(mistake nowhere near as good)
is there any way to reset the passwords if you go into console login?
thanks for your time
paul
PostPosted: Thu May 19, 2005 11:36 pm    Post subject: RE: pclinux login problem? Reply with quote
Hi
The passwords for PCLinuxOS are:
Guest = guest
Root = root
I hope the helps.
Regards jim
1slipperyfish
Forum Jester
PostPosted: Fri May 20, 2005 9:04 am    Post subject: Reply with quote
thanks a lot for that i got all in a muddle Very Happy
is that your password as it's your name or is it for everyone? Very Happy
paul
PostPosted: Fri May 20, 2005 11:24 am    Post subject: Reply with quote
Hi
To log in as Guest click on Guest in the login manager, then type guest in the password space.
Good Luck.
Jim
1slipperyfish
Forum Jester
PostPosted: Fri May 20, 2005 11:36 am    Post subject: Reply with quote
thakns jim Very Happy
i was just being daft rather than stupid Rolling Eyes (it can be difficult to tell)
paul
davecs
PostPosted: Mon May 23, 2005 10:54 am    Post subject: Reply with quote
You can of course change both passwords if you install it!
1slipperyfish
Forum Jester
PostPosted: Mon May 23, 2005 5:07 pm    Post subject: Reply with quote
thanks davecs but i'm having enough trouble getting my modem set up in mandriva at the minute Rolling Eyes
paul
