Help: FTP client for Windows
Postby guy » Mon Jun 05, 2006 11:23 am
I need to be able to change file and directory permisions on a Linux web server, using an FTP client on a Windows 98 box - hence this is a Windows question.
WS FTP Pro is pay-for.
I have been using CoreFTP, which is supposed to do this but that bit of the Help has not been writtemn yet and I can't figure it from scratch.
Does anybody know a free FTP client that does this, or how to do it in Core FTP?
RE: Help: FTP client for Windows
Postby M0PHP » Mon Jun 05, 2006 11:26 am
Image Image Image
M0PHP
Postby TheDoctor » Mon Jun 05, 2006 11:42 am
I use SmartFTP.
To change permissions, right click on the folder/file and select properties. You can also chmod the same way.
TheDoctor
Postby guy » Tue Jun 06, 2006 1:12 pm
Thanks folks. FileZilla needs 32-bit Windows, so I'll try Smart FTP and hopefully report back.
Postby Hello » Wed Jun 07, 2006 7:38 pm
A lot of people say flash fxp but I have used smartftp in the past and its worked fine.
Hello
Postby marco » Fri Jun 30, 2006 9:51 am
TheDoctor wrote:I use SmartFTP.
I use SmartFTP as well. It's a pretty good tool. I can highly recommend it.
marco
