mortezart
Posted: Fri May 19, 2006 2:12 pm Post subject: Sony Vaio, windows Xp does not work, only linux fedors boot |
Hello
I am a new user:
> I installed Linux feedura( from disc LXFSO5B/04/06), on my laptop(sony modelPCG-K33 vaio)
> right now I am only with Linux fedora, without windows xp, I have
some important data on my windows xp,
> how do i remove linux and then install it correctly?
all the best
Morteza
my email: morteza@morteza.org |
Gordon LXF regular
Joined: Thu Apr 07, 2005 6:01 pm Posts: 209 Location: Bradford, West Yorkshire
Posted: Fri May 19, 2006 5:00 pm Post subject: RE: Sony Vaio, windows Xp does not work, only linux fedors b |
Try making sure you have the following entry in the file
/boot/grub/menu.lst
| Code: |
title Windows XP Pro
chainloader (hd0,0)+1
Or it might need to be
| Code: |
chainloader (hd0,1)+1
On my sony vaio laptop the second is the one that boots xp since the first partition on the hard drive is the sony rescue system. _________________ Violence is the last refuge of the incompetent |
mortezart
Posted: Fri May 19, 2006 5:10 pm Post subject: RE: Sony Vaio, windows Xp does not work, only linux fedors b |
hello
I am using simply mepis3.4 now
where do i go to change the code?
could u please instruct me, step by step?
I am novice suer in linux?
last question: what distribution is better for laptops and dell pc? |
spottedcat LXF regular
Joined: Mon Oct 31, 2005 3:14 pm Posts: 971 Location: UK
Posted: Fri May 19, 2006 5:20 pm Post subject: RE: Sony Vaio, windows Xp does not work, only linux fedors b |
In Fedora 5, the file /boot/grub/menu.lst is actually called /boot/grub/grub.conf. Different distros use one of the two filenames, mortezart, but they both do the same thing. My Sony Vaio also has windows on the second partition so Gordon's second code is probably the one you want. Also, near the beginning of the file you'll find a line which says 'hiddenmenu' (without the quotes). Add a hash mark in front so that it looks like:
Actually, come to think of it, Gordon's line is probably already in there, but because of hiddenmenu you are not seeing it. Next time you boot up, as soon as you see the splash screen, hit the space bar and you should see the choice of Fedora or Windows. Use the up and own arrow keys and enter to make your choice. If you do see this and you want to lengthen the time before it boots into the default of Fedora, post back and either Gordon or I will tell you what to edit in grub.conf
Edit: You posted about Mepis before I finished my post. What are you seeing now? Can you boot into Windows? Mepis doesn't have a hiddenmenu. Don't worry - we'll get you sorted out. It's quite easy to edit the file. |
towy71 Moderator
Posted: Fri May 19, 2006 5:28 pm Post subject: RE: Sony Vaio, windows Xp does not work, only linux fedors b |
mepis, annoyingly remembers what you last booted and boots that automatically, can't remember what bit you have to comment out to stop it doing that though  _________________ still looking for that door into summer |
Posted: Fri May 19, 2006 5:37 pm Post subject: RE: Sony Vaio, windows Xp does not work, only linux fedors b |
It's quite possible, Towy, that the hidden hda1 partition on a Sony Vaio is confusing the installer. That's what happened to me when I installed SuSE 10.1. Halfway through the install at the reboot stage it booted me back into Windows - no choice at all. 'Handy,' I thought. Fortunately I was able to repair the SuSE menu.lst (or is that grub.conf? ), and carry on as thought nothing untoward had happened.
Despair not, mortezart. Help is at hand! |
nelz Moderator
Posted: Fri May 19, 2006 6:11 pm Post subject: Re: RE: Sony Vaio, windows Xp does not work, only linux fedo |
| towy71 wrote: | mepis, annoyingly remembers what you last booted and boots that automatically, can't remember what bit you have to comment out to stop it doing that though  |
Comment out "default lastsaved" in /boot/grub/menu.lst _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
GMorgan LXF regular
Joined: Thu Jan 12, 2006 6:58 pm Posts: 684 Location: South Wales, UK
Posted: Fri May 19, 2006 7:01 pm Post subject: RE: Re: RE: Sony Vaio, windows Xp does not work, only linux |
I thought grub.conf was a Gentoo tool. It's used there in case you want to unmerge GRUB (why would you ever want to do that). This way the file is maintained and a emerge just symbolic links menu.lst to grub.conf. Anyway I managed dual boot alright with Mepis, never noticed any last boot nonsense going on though that maybe because I altered GRUB myself or something (indeed I tore it apart when trying to get Nvidia to work with my new kernel. Nvidia as standard but hard work if you try to change something).
Anyway I've had success with Ubuntu on Laptops but haven't tried much else to be honest. |
towy71 Moderator
Posted: Fri May 19, 2006 8:23 pm Post subject: Re: RE: Sony Vaio, windows Xp does not work, only linux fedo |
| nelz wrote: | | Comment out "default lastsaved" in /boot/grub/menu.lst |
thanks nelz, where would we be without you  _________________ still looking for that door into summer |
nelz Moderator
Posted: Fri May 19, 2006 9:38 pm Post subject: RE: Re: RE: Sony Vaio, windows Xp does not work, only linux |
grub.conf isn't a tool, just a file. GRUB originally used grub.conf then switched to menu.lst. Many distros still symlink one to the other. It only matters which you use if you have /boot/grub on a filesystem where GRUB can't handle symlinks, like FAT or ISO9660. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
GMorgan LXF regular
Posted: Sat May 20, 2006 12:35 pm Post subject: RE: Re: RE: Sony Vaio, windows Xp does not work, only linux |
| My mistake then. With Gentoo storing all configurations in such files I assumed this was the same especially given the symlink. |
nelz Moderator
Posted: Sun May 21, 2006 9:28 am Post subject: RE: Re: RE: Sony Vaio, windows Xp does not work, only linux |
All distros store configurations in files, although Lindows used to keep passwords in a post-it note on the side of the monitor  _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
