IPCop and BT Connection
Postby MamaLizard » Mon May 15, 2006 3:07 pm
I am currently protecting my network (mixed Linux & Windows) using a dedicated box running IPCop firewall. This connects to BT ADSL via a Speedtouch USB modem, which is getting a bit old and creaky. Would like to have the 'up to 8mb' speed which apparently current modem does not support. Is there a simple ethernet modem (ie without firewall or anything too fancy) compatible with both BT and IPCop and not too complex to configure.
MamaLizard
RE: IPCop and BT Connection
Postby nelz » Mon May 15, 2006 3:15 pm
Ethernet modems with not router are few and far between. D-Link do one but I found it unreliable. I went back to my Origo modem/router, bought from Ebuyer, with the router switched off so it acts as a plain modem feeding my router.
Postby towy71 » Mon May 15, 2006 3:45 pm
Ebuyer have this safecom adsl modem router, it does have a firewall but that can be turned off. You could also look for the Binatone 2000 which does not have a built in firewall.
Postby MamaLizard » Mon May 15, 2006 6:28 pm
Thanks for the help. Will have a look at the modems/routers you suggest.
MamaLizard
Re: RE: IPCop and BT Connection
Postby Fargus » Wed Jul 19, 2006 10:42 am
nelz wrote:Ethernet modems with not router are few and far between. D-Link do one but I found it unreliable. I went back to my Origo modem/router, bought from Ebuyer, with the router switched off so it acts as a plain modem feeding my router.
I've been using the DLink one for about 3 years without a single issue! Works like a charm and has a browser configuration interface and even DHCP should you want it, but that can be turned off too.
Fargus
RE: Re: RE: IPCop and BT Connection
Postby nelz » Wed Jul 19, 2006 12:03 pm
It that the DSL-300T? Mine kept hanging, and I read other reports of the same on the web.
