stupid question
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic
pins
PostPosted: Fri May 05, 2006 10:33 pm    Post subject: stupid question Reply with quote
if you wanted to do something really stupid, would it be possible to set up grub/lilo to chain load grub/lilo from another drive, which was only set up to chain load the loader from the first drive, so that if there were no alternatives in the boot menu, someone would become stuck in an infinite cycle of boot loaders?
GMorgan
PostPosted: Fri May 05, 2006 11:05 pm    Post subject: RE: stupid question Reply with quote
I can't see why not. It wouldn't be an infinite loop though. You could edit a command manually.
PostPosted: Sat May 06, 2006 4:36 pm    Post subject: RE: stupid question Reply with quote
Unless you set the delay to zero, or perhaps just short enough to make someone think they can select a different option, but not quite.
GMorgan
PostPosted: Sat May 06, 2006 6:58 pm    Post subject: Re: RE: stupid question Reply with quote
Most computers I've tried will use commands issued before grub comes up though. If I have to leave during boot I will simply press the power button then hit up and down a few times then when I come back Grub will have paused allowing me to chose.
PostPosted: Sat May 06, 2006 9:03 pm    Post subject: RE: Re: RE: stupid question Reply with quote
I can't say I've tried that with either grub or lilo. I think we should just let pins try it and let us know. But from your post, it seems he will have to use lilo.
PostPosted: Fri May 19, 2006 12:02 pm    Post subject: RE: Re: RE: stupid question Reply with quote
Of course (grin). Iv'e had that set up for a few months now. But there other options included as well. If i'm bored i can just select and jump between lilo and grub (yaaawn)(grin).
All things are possible for the insidiously inclined, and the young at heart Smile
I also mistakenly had the wrong root directory configured in my lilo.conf file once. I think it was for ubunto but can't remenber. It was kinda funny, because i was using the same home directory and as i do all my personal stuff in seperate partitions that can be mounted cross distro, i didn't even notice for a week or so (grin)
Humpty Dumpty Was Pushed !
1slipperyfish
Forum Jester
PostPosted: Fri May 26, 2006 10:34 am    Post subject: Reply with quote
i'm not an expert but, isn't this computer related chat? shouldn't the moderators remove this post?
paul
PostPosted: Fri May 26, 2006 10:58 am    Post subject: Reply with quote
No, you're not. Yes, it is. Yes, they should. No, they won't Wink
moAlleyCat
PostPosted: Mon Jul 03, 2006 9:51 pm    Post subject: Reply with quote
If you wanted to do something really stupid, would it be possible to totally smack your computer up with a baseball bat?
PostPosted: Mon Jul 03, 2006 10:44 pm    Post subject: Reply with quote
It would seem more so after you calmed down later, i would think Smile.
It's not really a stupid idea either. It can be a fun/revealing way to test the flexibilities that are available, but often just aren't put to use. If a person dosen't muck/experiment around with facilities then all they can do really, is just missread the docs. Or be limited to the extent that the documentation explaination/description decides to go.
Changing the root mount can be fun too, in loader configs. As long as the appropriate module dir is copied over it usually can be done with out much notice. I usually have most of my kernel stuff builtin, except for common things like filesystems, so they tend to all get referenced by the module configs anyway.
Madness with purpose becomes not, so to speak Smile
http://counter.li.org
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic All times are GMT
